It85xx datasheet
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    It85xx datasheet
    I'm searching a datasheet of ite it85xx, any version is disponible.
    thanks
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: It85xx datasheet
    Follow the link-
    • Rainbow_Chameleon
      Searching Datasheet for AM113 IC by O2MICRO
      by Rainbow_Chameleon
      I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
      Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
      If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
      On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
      So if anyone has a datasheet or at least...
      01-23-2025, 12:03 PM
    • SoulFreeze
      Help finding datasheet for component marked G34662
      by SoulFreeze
      Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
      Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
      Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
      05-01-2025, 03:56 AM
      Surface Mount Fuses Fundamentals Datasheet
      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
      10-07-2024, 06:07 AM
    • jordanaudio1
      Samsung TV UN60KU6270F power supply
      by jordanaudio1
      Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
      My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
      07-07-2025, 07:38 PM
    • Bartoloni
      Searching info of this PD controller: PS8743B (in a Toshiba Satellite PRO )
      by Bartoloni
      the laptop is starting ONLY if a usb drive (or a mouse) is connected on the Type-c port.. leaving it empty hangs startup on DynaBook BIOS LOGO (never seen something like this)
      searching for the VCC pin . .just to disable it without removing the chip.
      08-24-2024, 08:41 AM
