Hp 1000 backlight problem
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    I have this hp1000 6050A2493101-MB-A02 with no backlight. I have got all the voltages at the lvds connector, 19v, 3.3v but still no backlight.
    Can anyone point me to where I can locate the Backlight enable pin at the back of the LED screen?
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Hp 1000 backlight problem
    Still waiting for an idea
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Ok if you dont have schematic then download the data sheet for the led and check.You have 200 posts so your not new to repairs.
      Have a look at page 38
      • Djosla
        • Dec 2012
        • 246
        • Montenegro
        Pin 22 is enable and should be 3,3v
        pin 21 pwm should have 1,5-3,3v it`s brithness control
        pins 1,2 should be 3.3v lcd power supply
        pins 23,24 should be 19v backlight power supply
        • bluestone
          • Jun 2011
          • 343
          • Ghana
          Thanks cyberhack and Djosla, I already have the schematics of this board and up on checking the connection shown on the schematic on cn503 is not what is on the board.
          pin22 which is LCD_BKEN is 3.3v, pin1,2 which is LCDVDD is 3.3 but the 19v backlight power is not at pin 23,24 it is rather at pin 29,30. I have checked different kind of schematics is it is the same configuration.
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            First is CN503 on the pcb a 30 pin and you have removed the led ie unpluged it
            as it will damage with 19 volts going to the led make sure you have the right schematic
            i would download the led data sheet .
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              Maybe quanta got all this schematics wrong, the pin 29 and 30 is the 19v Lcd Power, not pin 23,24 as stated in the schematic. I have been able to resolve the problem,
              I noticed that there was no voltage at pin21 which is PCH_LCD_PWM, so I realized this voltage is supposed to come from the PCH so I soldered PIN 22 and 21 together and now backlight is on. I just didn't want to reflow the PCH. Thanks to all of you. I hope you can keep it for reference.
              • dammysholove
                • Jun 2017
                • 59
                • nigeria
                it saved me now.. thanks
                • ballenian
                  • Feb 2011
                  Thanks cyberhack, it saved my day
                  • Dobrowol
                    Asus GA402RK keyboard and kb backlight problem
                    by Dobrowol
                    Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                    04-28-2025, 04:30 PM
                  • ononos
                    LG M2362DP Backlight problem
                    by ononos
                    hello everyone!
                    As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                    I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                    So i decided to try to...
                    03-12-2023, 05:05 AM
                  • fanaticgames
                    Samsung UE32D4010 Backlight problem, led ok
                    by fanaticgames
                    hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                    02-22-2023, 09:46 AM
                  • Honziq
                    Backlight problem - Asus M3200WU, board Gapal LA-L291p
                    by Honziq
                    I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                    I was repaired many backlights before but this design i will not understand.
                    For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                    Can someone explain me please what to do, what to check?
                    Thanks....
                    11-20-2024, 01:24 PM
                  • grbo92
                    Backlight problem Acer LA-031P
                    by grbo92
                    i have one acer Nitro 5 without backlight on my desk.
                    Mainboard model: LA-L031P GH53Z REV 1B
                    Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                    11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                    Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                    Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                    09-09-2024, 03:49 AM
