identify component: red-brown with white Q
  • ghp
    • Sep 2016
    • 11
    • Belgium
    Would someone tell me what the component is on the attached image? Red-brown color marked with white uppercase Q.
    Thanks,
    Gerard
  • khaahk
    • Dec 2013
    • 818
    • Estonia
    Re: identify component: red-brown with white Q
    A fuse of some sort. Rating might come from schematic if mainboard platform can be identified.
    • relax79
      • Jul 2014
      • 52
      • TURKEY
      Sorry for my poor English. This is "very fast acting fuse" Q is value of the fuse but I do not know exactly values and codes standart or not to all manifacturer. What is your motherboard model, you maybe find the schematic for identify to part exact code. In the attachment page 92 and 93 only example for you, they are not might be exactly your searching part.
      • piernov
        • Jan 2016
        • 4439
        • France
        We can see a 10mΩ resistor nearby, probably a current sensing resistor so the fuse might be at least rated for a few amps (3-10A ?).
        • ghp
          • Sep 2016
          • 11
          • Belgium
          The motherboard belongs to a Toshiba C855-P21, intel core I3 + amd gpu, the image attached is not mine but a lookalike. What is the symbol for a fuse on a schema?
          Thank you all!
          • relax79
            • Jul 2014
            • 52
            • TURKEY
            Your board is "PLF/PLR/CSF/CSR DSC MB" if I am not wrong.This motherboard not have exact schematic in net but in the attachment page 5 you see fuse6000 8,10,12A. I think your fuse value is 10A like in the SMD FUSE pdf page 93.
            • ghp
              • Sep 2016
              • 11
              • Belgium
              This is exactly what I was looking for: Q = 10A vfa fuse. Bingo.
              • relax79
                • Jul 2014
                • 52
                • TURKEY
                What is your motherboards problem exactly?. If the fuse blow or open circuit then quite possible something big problem (strong short circuit power lines or supplys) happen in your motherboard. Fuses protect for when over current the own value.
                • ghp
                  • Sep 2016
                  • 11
                  • Belgium
                  My friend used a power supply with wrong polarity. I'd like to find what components have been damaged.
                  • relax79
                    • Jul 2014
                    • 52
                    • TURKEY
                    You must be check "PVADPTR" to GND and "PVBAT" to GND lines for short circuit or low ohm using multimeter before installing new fuse, if there is short then probably blow again your new fuse.If it is not short then probably work.
                    • ghp
                      • Sep 2016
                      • 11
                      • Belgium
                      Couple of questions.
                      According to http://mayohardware.blogspot.be/2011...g-mosfets.html I should be reading between 100 and 500 on the mosfets with a diode test. That's OK for the F8707, but on the FDMC 8884 I read only 64. Moreover, it looks a lot as if gate and source are shorted on the 8884, as with https://www.badcaps.net/forum/showthread.php?t=41206.
                      Then I have a short to ground where I've drawn two connected red circles on the attached picture. I didn't expect this, but maybe it's normal?
                      I would have liked to determine that myself, using the schema earlier in this thread, but I cannot even locate the 2R2 resistor on that schema. Can someone point me in the right direction?
                      Thanks,
                      Gerard
                      • ghp
                        • Sep 2016
                        • 11
                        • Belgium
                        I've removed the two components of which I'm sure they're toast.
                        Still hope someone (relax79?) will tell me if the short to ground is a problem.
                        • khaahk
                          • Dec 2013
                          • 818
                          • Estonia
                          There should not be short to ground across the capacitor, from the picture it is hard to tell how the cap is connected in the circuit, one side of the cap must be on the ground...
                          • ghp
                            • Sep 2016
                            • 11
                            • Belgium
                            No "short to ground", but "on the ground": can you tell me what distinguishes the two?
                            On other Toshiba schemas I found plenty of these combinations: 2.2k resister - capacitor - ground.
                            Thanks, Gerard
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              PLF/PLR/CSF/CSR DSC MB = Pegatron, schematic hard to find it on web. (you could try seek the boardview)
                              So we must use other schema as refer.
                              -AIC70
                              -VA70HW GDDR5
                              then we need to know AC_BAT_SYS have no short sircuits
                              Image HD1, HD2
                              Hope this helps
                              • ghp
                                • Sep 2016
                                • 11
                                • Belgium
                                It sure helped, Meritosari, and the board is indeed a Pegatron, I found the code underneath the keyboard (where there was also an opening through which you could replace the fuse!).
                                It was enough to replace the FDMC8884 and the laptop was functioning again.
                                Thanks everyone!
                                • ghp
                                  • Sep 2016
                                  • 11
                                  • Belgium
                                  Originally posted by ghp
                                  II found the code underneath the keyboard
                                  That was the code for the keyboard itself
                                  • Francesc V.
                                    Help me to identify this Thermal fuse from my sister's mixer
                                    by Francesc V.
                                    Hi everyone:
                                    This is the second time I have my sister's mixer on the bench. First time I identified a blown tiristor......this time I guess it's the thermal fuse (reads open).
                                    My understanding is that it should be (NC) normally closed and open at 85C?????
                                    Could you help me to identify/get a good one? How many amps? I was about to buy a NC 10A, 85 celcius in Aliexpress. (ceramic one)......but I guess is too much.
                                    Wording in the back......... "limitor 16", "T160".
                                    Thanks in advance,
                                    Francesc....
                                    03-18-2025, 05:48 AM
                                    MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-06-2024, 07:46 AM
                                    MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                    09-06-2024, 07:29 AM
                                    MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-06-2024, 07:25 AM
                                    MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                    This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
