HP 1000 doesn't power up without AC charger
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Laptop says, "plug in, charging" but actually no progress. When I unplug the charger, it goes powering off instant. With another battery having 70%+ charge, it's not powering up.
    Changing battery is not the solution.
    Is it a BIOS fault?
    or Charging Ic?
    It has BQ24728/BQ728 charge controller chip.
    Help me guys. Thanks.
  • sivakumar
    • Mar 2016
    • india
    Re: HP 1000 doesn't power up without AC charger
    hasee hec41 not powering on.
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
