Hp G62 problem
  • allione
    • Jul 2016
    • 5
    • ghana
    Hp G62 problem
    pls I need help agently,I have with me Hp G62,it on's directly when you put the charger and when you off and on it with the switch it doesn't on,can someone help pls
  • angel-boy
    • 550
    Re: Hp G62 problem
    Try to make one topic , not two
    • mrwab
      Banned
      • Jan 2014
      • 83
      • morocco
      Re: Hp G62 problem
      try make jump in power switch between 3.3V in stand by mode and gnd
      • hyditech
        • Jun 2012
        • 272
        • nigeria
        Re: Hp G62 problem
        Change the switch
          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 05:30 AM
        • motormayhem
          Lenovo T460 Only Charges on One Charger
          by motormayhem
          Laptop Question
          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
          05-12-2023, 01:46 PM
        • Natob82
          Micro Momentary Push Switch?
          by Natob82
          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
          12-21-2022, 05:22 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • grimacelord
          NEC TurboExpress On/Off Power Switch Replacement Help
          by grimacelord
          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
          11-09-2023, 09:49 AM
