Strange problem in Asus K56cm
  • maxoscar
    • Apr 2015
    • 10
    • syria
    Hello
    I have the below problem in Asus K56cm
    The laptop is unable to boot from the AC alone or from the battery alone
    Not been able to power on the laptop
    By accident I have discovered that if the AC and Battery are exist together I was able to power on and boot but based on battery power
    I have unplug AC Then I was unable to power on the laptop and vise versa
    the only way is to have them both connected and it will bot based on the battery
    Any suggestion to fix this issue
    thanks in advance
  • samanthban
    • Feb 2014
    • 253
    • Sri lanka
    Re: Strange problem in Asus K56cm
    ec bios suspected
    sigpic
    • maxoscar
      • Apr 2015
      • 10
      • syria
      Thanks for your answer , do you mean to program the bios again
      • lazaro.089
        Asus Zephyrus M16 / GU603ZW problem
        by lazaro.089
        Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
        CPU: Core i9-12900H
        Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
        Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
        The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
        08-26-2025, 06:33 PM
      • AtelierRepa
        ASUS X712JA problem
        by AtelierRepa
        I have a problem with the bios, let me explain.
        With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
        I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
        My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
        The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
        06-15-2024, 04:33 AM
      • greg1985
        Asus dabkxmb18b0 rev.b bios problem
        by greg1985
        Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
        I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
        I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
        10-20-2025, 11:34 AM
      • boticario
        problem with asus tuf A17 FA707NUR
        by boticario
        I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
        The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
        After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
        I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
        10-18-2025, 04:37 PM
      • boticario
        by boticario
        10-14-2025, 08:38 PM
