Pavilion G6 dead
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Pavilion G6 dead
    Hello Guys,
    There is a problem in my HP G6 with mobo DA0R33MB6E0 REV:E R33
    At first, the board would start, but black screen.
    I programmed both eeproms, but no chnage.
    Than suddenly, there was a shortage on the board and nothing works anymore. I think I found the shortage in PQ11 and PU5. I replaced them, no shortage anymore but also no life in mobo.
    I measured the following voltages up til now,
    PU8, PU5 and PU9, see text files.
    on/off switch has 3,3v
    Can somebody pls help me to look in the right direction?
    thx
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: Pavilion G6 dead
    Pls Guys, I need some help.
    I have been checking voltages around U9 and the schematic says ACDET=13V,but I measure 3v. No leds are comming on so I would think that the signal should be 13V. But where is this 13V made. At +VAD_1 I have 19V, but after resistor PR47 it have 3V and also at +PWRSRC it has 19V and after resistor PR100 it shows 3V. Is there a mistake?
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      YOU are say that on/off switch has 3,3v
      and says ACDET=13V,but I measure 3v.
      and you are in pin 8 SDA AND PIN 9 SCL =0VOLT
      I THINK that your bq is damaged
      tel me about the pin 77.78 OF KB3940 PAGE 30 how is the volt .if you found 3.3v you can changing your PU9 =BQ24738
      • bicalov
        • Nov 2014
        • 294
        • Netherlands
        Thanks for reaction.
        I do not have 3V on on/off switch anymore, I don't know why.
        On pin 77 and 78 on KB3940 = 0V
        I said that ACDET is 13V, but that is not me, this is written on the schematics.
        • ridamouh159
          • Nov 2014
          • 365
          • maroc
          you can forgot now the pq .
          so you have in pin16= 17,5v of pu8 EXACT
          have you 3.3v in pin 8 of kbc bios.
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            PU8 pin 16=14,68V
            U18 pin 8 = 0V
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              so we must return back
              have you 19v in PQ50
              • bicalov
                • Nov 2014
                • 294
                • Netherlands
                19,82V on all pins
                • ridamouh159
                  • Nov 2014
                  • 365
                  • maroc
                  I think that the problem is in PU8 or in the around of him .
                  v out 7= 0v
                  vreg5 pin17= 4,6v you must found 5.10v
                  vreg 3 pin8= 3,3v ok
                  pin 10 -11-12-5-21-22-19 no good
                  p in -PU8 pin 16- you must found 19v
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    Sorry for the delay and thx for your patience.
                    I am very confused now, because the previous voltage I measured changed.
                    PU8: pin 8 =0,5v pin 9= 4,35v
                    pin 7= 0v. pin17=4,24v
                    pin16= 7,02v
                    I don't know why this happened.
                    I found EC12 and PC95 with 1 side burned. EC12 more than PC95.
                    I will try and replace PU8 tomorrow.
                    • bicalov
                      • Nov 2014
                      • 294
                      • Netherlands
                      Finally I got to replace PU8 and the 2 capacitors EC12 and PC95.
                      the readings on PU8 are now:
                      pin 1,2,5,6,7,10,11,12,14,15,18,19,20,21,23,24 are 0V
                      pin 3= 2,86V
                      pin 4= 5,02V
                      pin 8= 3,35V
                      pin 9= 4,57V
                      pin 13= 2,86V
                      pin 16= 19,86V
                      pin 17= 5,10V
                      pin 22= 4,57V
                      Now on U18 pin8= 3,35V
                      Also on U14 pin 77,78= 3,35V
                      • ridamouh159
                        • Nov 2014
                        • 365
                        • maroc
                        NOW the work is ok
                        IF the problem is not solved
                        what about PQ35-PQ54 HAVE YOU 3.3V
                        AND PQ51-PQ52 have you 5.10v
                        and now YOU are in on/off switch 3,3v
                        if all is ok and you are 3.3v (sometimes no ) in pin 8 of U31 (PCH SPI ROM -page7)
                        if yes you make return your 2 dumps after (I programmed both eeproms, but no chnage)
                        IF stay teh same you flashing with any g6 BID 0183A.
                        good chance
                        the photos i put him with is for G6-2149sf he coming to me with chip problem in 2014 .
                        my english language is bad therefore i can't exprime or discuse good.
                        • ridamouh159
                          • Nov 2014
                          • 365
                          • maroc
                          I must no asking you about PQ50 because your measured pin 4 ACDRV =19.80V coming from PQ50 .
                          • bicalov
                            • Nov 2014
                            • 294
                            • Netherlands
                            Don't worry about the English, you are doing very good and I am very happy you're helping me. I speak English for years, also at home, so I can understand you very well.
                            Powerswitch has 3,32V
                            PQ51: pin 5,6,7,8 = 19,82V ; pin1,2,3=0V ; pin 4=0V
                            PQ52: all pins 0V
                            PQ54: pin 5,6,7,8 = 19,82V ; pin1,2,3=0V ; pin 4=0V
                            PQ53: all pins 0V
                            U31 PIN 8=0V
                            No leds on at all
                            • bicalov
                              • Nov 2014
                              • 294
                              • Netherlands
                              I don't have a problem with that, better to be sure.
                              • ridamouh159
                                • Nov 2014
                                • 365
                                • maroc
                                now sure the problem is in PU8 or around him
                                i think that a composant as PQ51-PQ52- PQ54 -PQ53 cause the damage for pu8
                                search for a short ciruit in 4 mosfet or an other composant near from
                                and make sure that your pu8 is good placed
                                • ridamouh159
                                  • Nov 2014
                                  • 365
                                  • maroc
                                  how is the volt in pin 7 out2 and pin 24 out1 and pin 23 PGOOD of PU8
                                  • bicalov
                                    • Nov 2014
                                    • 294
                                    • Netherlands
                                    PU8 pin 7, 24 and 23 are 0V
                                    I will look if I can find shortag
                                    Before you say,that if pin 77 and 78 of KB3940 are 3,3V, replace BQ24738.
                                    Now the pins 77 and 78 are 3.35V again. Should I replace?
                                    • bicalov
                                      • Nov 2014
                                      • 294
                                      • Netherlands
                                      PL16 had a loose contact and I replaced it. After that, PU5 get's very hot, so there is a shortage somewhere. Can you advise where to look?
                                      On PC211 I have 56 Ohm
                                      • ridamouh159
                                        • Nov 2014
                                        • 365
                                        • maroc
                                        before sda and scl =0v and the 3.3 v is corupted by pu8 after changing it is ok and you must forgot bq now .
                                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 03:44 PM
                                          HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP Pavilion Pavilion Desktop - 570-p030na Pavilion 570 i3-7100 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Desktop - 570-p030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p030na boardview and Pavilion Pavilion Desktop - 570-p030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
