Pavilion G6 dead
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Pavilion G6 dead
    Hello Guys,
    There is a problem in my HP G6 with mobo DA0R33MB6E0 REV:E R33
    At first, the board would start, but black screen.
    I programmed both eeproms, but no chnage.
    Than suddenly, there was a shortage on the board and nothing works anymore. I think I found the shortage in PQ11 and PU5. I replaced them, no shortage anymore but also no life in mobo.
    I measured the following voltages up til now,
    PU8, PU5 and PU9, see text files.
    on/off switch has 3,3v
    Can somebody pls help me to look in the right direction?
    thx
  • bicalov
    • Nov 2014
    • 294
    • Netherlands
    Re: Pavilion G6 dead
    Pls Guys, I need some help.
    I have been checking voltages around U9 and the schematic says ACDET=13V,but I measure 3v. No leds are comming on so I would think that the signal should be 13V. But where is this 13V made. At +VAD_1 I have 19V, but after resistor PR47 it have 3V and also at +PWRSRC it has 19V and after resistor PR100 it shows 3V. Is there a mistake?
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      YOU are say that on/off switch has 3,3v
      and says ACDET=13V,but I measure 3v.
      and you are in pin 8 SDA AND PIN 9 SCL =0VOLT
      I THINK that your bq is damaged
      tel me about the pin 77.78 OF KB3940 PAGE 30 how is the volt .if you found 3.3v you can changing your PU9 =BQ24738
      • bicalov
        • Nov 2014
        • 294
        • Netherlands
        Thanks for reaction.
        I do not have 3V on on/off switch anymore, I don't know why.
        On pin 77 and 78 on KB3940 = 0V
        I said that ACDET is 13V, but that is not me, this is written on the schematics.
        • ridamouh159
          • Nov 2014
          • 365
          • maroc
          you can forgot now the pq .
          so you have in pin16= 17,5v of pu8 EXACT
          have you 3.3v in pin 8 of kbc bios.
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            PU8 pin 16=14,68V
            U18 pin 8 = 0V
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              so we must return back
              have you 19v in PQ50
              • bicalov
                • Nov 2014
                • 294
                • Netherlands
                19,82V on all pins
                • ridamouh159
                  • Nov 2014
                  • 365
                  • maroc
                  I think that the problem is in PU8 or in the around of him .
                  v out 7= 0v
                  vreg5 pin17= 4,6v you must found 5.10v
                  vreg 3 pin8= 3,3v ok
                  pin 10 -11-12-5-21-22-19 no good
                  p in -PU8 pin 16- you must found 19v
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    Sorry for the delay and thx for your patience.
                    I am very confused now, because the previous voltage I measured changed.
                    PU8: pin 8 =0,5v pin 9= 4,35v
                    pin 7= 0v. pin17=4,24v
                    pin16= 7,02v
                    I don't know why this happened.
                    I found EC12 and PC95 with 1 side burned. EC12 more than PC95.
                    I will try and replace PU8 tomorrow.
                    • bicalov
                      • Nov 2014
                      • 294
                      • Netherlands
                      Finally I got to replace PU8 and the 2 capacitors EC12 and PC95.
                      the readings on PU8 are now:
                      pin 1,2,5,6,7,10,11,12,14,15,18,19,20,21,23,24 are 0V
                      pin 3= 2,86V
                      pin 4= 5,02V
                      pin 8= 3,35V
                      pin 9= 4,57V
                      pin 13= 2,86V
                      pin 16= 19,86V
                      pin 17= 5,10V
                      pin 22= 4,57V
                      Now on U18 pin8= 3,35V
                      Also on U14 pin 77,78= 3,35V
                      • ridamouh159
                        • Nov 2014
                        • 365
                        • maroc
                        NOW the work is ok
                        IF the problem is not solved
                        what about PQ35-PQ54 HAVE YOU 3.3V
                        AND PQ51-PQ52 have you 5.10v
                        and now YOU are in on/off switch 3,3v
                        if all is ok and you are 3.3v (sometimes no ) in pin 8 of U31 (PCH SPI ROM -page7)
                        if yes you make return your 2 dumps after (I programmed both eeproms, but no chnage)
                        IF stay teh same you flashing with any g6 BID 0183A.
                        good chance
                        the photos i put him with is for G6-2149sf he coming to me with chip problem in 2014 .
                        my english language is bad therefore i can't exprime or discuse good.
                        • ridamouh159
                          • Nov 2014
                          • 365
                          • maroc
                          I must no asking you about PQ50 because your measured pin 4 ACDRV =19.80V coming from PQ50 .
                          • bicalov
                            • Nov 2014
                            • 294
                            • Netherlands
                            Don't worry about the English, you are doing very good and I am very happy you're helping me. I speak English for years, also at home, so I can understand you very well.
                            Powerswitch has 3,32V
                            PQ51: pin 5,6,7,8 = 19,82V ; pin1,2,3=0V ; pin 4=0V
                            PQ52: all pins 0V
                            PQ54: pin 5,6,7,8 = 19,82V ; pin1,2,3=0V ; pin 4=0V
                            PQ53: all pins 0V
                            U31 PIN 8=0V
                            No leds on at all
                            • bicalov
                              • Nov 2014
                              • 294
                              • Netherlands
                              I don't have a problem with that, better to be sure.
                              • ridamouh159
                                • Nov 2014
                                • 365
                                • maroc
                                now sure the problem is in PU8 or around him
                                i think that a composant as PQ51-PQ52- PQ54 -PQ53 cause the damage for pu8
                                search for a short ciruit in 4 mosfet or an other composant near from
                                and make sure that your pu8 is good placed
                                • ridamouh159
                                  • Nov 2014
                                  • 365
                                  • maroc
                                  how is the volt in pin 7 out2 and pin 24 out1 and pin 23 PGOOD of PU8
                                  • bicalov
                                    • Nov 2014
                                    • 294
                                    • Netherlands
                                    PU8 pin 7, 24 and 23 are 0V
                                    I will look if I can find shortag
                                    Before you say,that if pin 77 and 78 of KB3940 are 3,3V, replace BQ24738.
                                    Now the pins 77 and 78 are 3.35V again. Should I replace?
                                    • bicalov
                                      • Nov 2014
                                      • 294
                                      • Netherlands
                                      PL16 had a loose contact and I replaced it. After that, PU5 get's very hot, so there is a shortage somewhere. Can you advise where to look?
                                      On PC211 I have 56 Ohm
                                      • ridamouh159
                                        • Nov 2014
                                        • 365
                                        • maroc
                                        before sda and scl =0v and the 3.3 v is corupted by pu8 after changing it is ok and you must forgot bq now .
