DELL Inspiron N7010 turn off
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello i got this N7010 Dell Inspiron and it turn off after 5-8 sec.
    It stating normally show DELL logo and then after 5 sec turn off. I can turn it on immediately and then again turn of after 5 sec.
    When i leave it turned off 10min and then turn it on it stay on maybe 20 seconds.
    i change the thermal paste, check with another adapter no help.
    what do you think this could be?
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: DELL Inspiron N7010 turn off
    board model: DAUM9BMB6DO REV: D
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      can this be a capacitor problem?
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        i have the same problem , you have solved it or not?
        • gcomputers
          • Apr 2013
          • 509
          • Albania
          Solved , shoot down from graphic card failure. Reflowed gpu and turn on normally . So need to replace Gpu with new.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            I did not fix it, but i too suspected that was GPU fail
            • nixi22
              • May 2016
              • 44
              • Croatia
              Simplest thing did you check bios battery, can u enter in bios during that time, if your machine is using intel HD gpu which is inside of cpu (i3) i dont think that is gpu issues.
              • dspok
                • Jan 2014
                • 553
                • Nepal
                I never encounter such a problem with GPU failure.
                Disconnect all devices I.e hdd, dvd etc etc and try again.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  It is a common problem on that model Dell and the N5010. The heatsink is held onto the ATI GPU with a single screw on one side and it gets loose. The thermal pad dries out and the GPU overheats to the point of the machine shutting down within minutes.
                  Not in all cases does the GPU fail on these machines. Sometimes just replacing the thermal pad with a 1mm thick copper shim, using good quality thermal paste on both sides, is all that's needed to get it back to working condition.
                  A working TV? How boring!
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    well the _unique as a nice teory , that in fact could be the issue regarding this machine , but alltough dell have many 19v problems .. if you do not have a regular 19 volts line all over the board , then you will have many random shutdowns . carefully chek vcore line for 19 volts and main dc in including charging circuit. , doesn't take long and its a basic chek :P
                    • Prosatanosz
                      • Nov 2015
                      • 108
                      • Hungary
                      Same problem. VGA reflow helped!
                      • Naineesh1
                        DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
                        by Naineesh1
                        I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
                        Schematic diagram : bios chip volt...
                        07-05-2025, 01:20 AM
                        DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                        This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        09-12-2024, 03:36 PM
                        DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                        This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        09-12-2024, 03:30 PM
                        DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                        This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        09-12-2024, 03:28 PM
