hp 2000 shut off within 30 min.
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    hello friends pls give me solution for this kind of problem.
    m/b part no. 010170100-491-g
    newton cr&hr_hpc
    mv_mb_v1
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: hp 2000 shut off within 30 min.
    did you check the temps ?
    • Djosla
      • Dec 2012
      • 246
      • Montenegro
      if temps are ok...than you need to clean me region of your bios...
      • mitu_sharma
        • Jul 2015
        • 182
        • india
        i chk the temp it is normal
        how do i cleran me region of bios
        pls help
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          here is dump from different model but same motherboard
          sp66781 is update from web and has clean me and no dmi data in it
          1858 is the one you need
          Im Back... sort of...
          • mitu_sharma
            • Jul 2015
            • 182
            • india
            thanks borbe
            but tell me one thing i can do (clean me region) myself
            how is it possible
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              search on youtube
              • alihomee
                • Dec 2012
                • 1575
                • malaysia
                hahahaahhahaah ala-borbe is not in the mood to teach...........sharma did u solve the problem with that files given by ala_borbe
                • mitu_sharma
                  • Jul 2015
                  • 182
                  • india
                  not yet
                  • mitu_sharma
                    • Jul 2015
                    • 182
                    • india
                    write all bios given by borbe but no luck
                    what i do pls help
                    • the-sky-blue
                      • Dec 2013
                      • 48
                      • salfeet
                      just clean cpu fan and change thermal pads ...
                      last think maybe you need to update bios .
                      • Joseph cauchi
                        jccomputers
                        • Jan 2015
                        • 89
                        • Malta
                        Please explain how to update the bios? Do not think everybody is like you .with a short answer you do not solve any problems.
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          this issue is happening due to bad HUB , in this case cpu is not supported by PCH , first , chek CPU model code , and therefore , chek whitch PCH you have on board , then chek if the cpu you are using is compatible on the pch table . my bet is that it wont be .
                          the exact 30 minutes shutdown is a simple protection of the HUB since is detecting anormalities on cpu line .
                          IF cpu is correct with PCH , then your bios is not ok , you must rewrite for the correct pch / ME region
                          cheers
                          Alihome , its not that ala borbe dont want to teach , but its something that requires a lot of step to be teached on forum , but as it mentioned youtube explain very well , including link of how to do it , and were to get the regions files , etc
                          Also to avoid this kind of comments , they are certain things , that not even need of an answer since does answer are usually on first google page :P
                          now more technician electronics issues ,are more hard to find , so thats its ok of asking all this infos here
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            joseph , its easy to flash , first do you have a rom flasher ? for ex TL866CS minipro .
                            if you got one of does units , follow this steps
                            1- chek board code , with this board code it will be easyer to find a decent dump
                            2- desolder the bios chip on the board , read on the programmer , and save the reading you've done .
                            3- import to mini pro programmer , the dump you donwloaded , and press Programming.
                            4- resolder back the rom chip and try it out
                            • mitu_sharma
                              • Jul 2015
                              • 182
                              • india
                              thanks highpluse
                              in short i do everything but no result, it has hm70 finally i am searching flash image tool for hm70 i did not get.
                              sorry one more thing i have change core i3 CPU instead of dualcore. so what will i do
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                so you got hm70
                                hold on
                                so for HM/= cpu support are the following ones
                                Intel Mobile Celeron Dual-Core
                                1000M - AW8063801120200
                                1000M, 1.8 GHz, L3 2 MB
                                1007U - AV8063801118700
                                1007U, 1.5 GHz, L3 2 MB
                                1020M - AW8063801443700
                                1020M, 2.1 GHz, L3 2 MB
                                1037U - AV8063801442900
                                1037U, 1.8 GHz, L3 2 MB
                                Intel Pentium Dual-Core Mobile
                                2020M - AW8063801033501 / AW8063801211202 / AW8063801539300
                                2020M, 2.4 GHz, L3 2 MB
                                2030M - AW8063801120500 / AW8063801208800
                                2030M, 2.5 GHz, L3 2 MB
                                2117U - AV8063801058800
                                2117U, 1.8 GHz, L3 2 MB
                                2127U - AV8063801119100
                                2127U, 1.9 GHz, L3 2 MB
                                2129Y - AV8063801377901
                                2129Y, 1.1 GHz, L3 2 MB
                                Data source:
                                chek if you is one of does , if you got hm70 it will work with simple dual core cpu , it might not work with your i3 , unless you change the hub and bios
                                • mitu_sharma
                                  • Jul 2015
                                  • 182
                                  • india
                                  u mean to say that i3 cpu is not supported on hm70,
                                  according to u (highpluse), i replace the cpu with penitum dualcore but still same
                                  this kind of problem has been me region, can u provide me flash image tool for hm70. genius i am waiting for ur reply thanx.
                                  • mitu_sharma
                                    • Jul 2015
                                    • 182
                                    • india
                                    pls do something i am in trouble.
                                    • ala_borbe
                                      aka Donald
                                      • 1625
                                      • Malta
                                      post 5 file SP66781.zip has bios with clean me for that motherboard
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1488
                                        • portugal
                                        mitu sharma , the cpu that you inserted on the machine hass a code , like "SLxxx" , put this code on google and chek wich is the dual core you inserted and chek with the list i gave you above not all dual cores are accepted mate ) if yours is one of the names on the list , then flash bios with the bios file found on post number 5 of this thread as ala_borbe mentioned.
