Hi Friends.... Help me. I am in a trouble. This is Acer Aspire 5742GZ and LA-5891P mother board. This one, power on but no VGA power supply and PLTRST. PCH Crystal and BIOS CS Pin Not function with Oscilloscope. PCH power Supply OK. VGA power on signal not coming from PCH. I gave manual signal for VGA power supply. Then VGA power comes. But no display. As you think PCH Bad or another Idea. Thanks.
					Acer LA-5891P
 Assuming...7 Photos
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
 Opened it up and discovered the power supply is making a faint clicking or ticking sound.
 I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
 I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
			Have had two Acer K272HUL monitors die with the same symptoms:
 - Blue power light is illuminated while the monitor is plugged in
 - Black screen (no splash screen, etc.)
 - Power button doesn't do anything
 Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
 Power supply voltages are fine.
 There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
 Anyone have any ideas?...-
 12-09-2023, 10:22 PM
- Loading...
