Compaq CQ62 power problem
  • savo.lekic
    • Mar 2013
    • 10
    • Montenegro
    Hi guys,
    have problems with compaq cq62. Laptop sometimes starts, works fine for some time and start switching between AC and battery. AC adaptor is ok, checked voltages, so are adaptor connector going on motherboard. When working normally all voltages readings are fine (checked only few components following DCIN).
    After some time LED signal (ACLED on image 1 in attachments) on connector stops shining and I hear component on motherboard clicking, as it appears to me it is coming from inductor PL7 (1R0). Also voltages which are in normal mode stable start to changle in clicking rithm. Anyone had similar problem?
    Voltages reading in working mode:
    DCIN = 19.48V
    PQ37 Drain = 19.15V
    PQ36 pin 4 = 9.59V
    PQ55 Gate = 19.28V
    when stops working all voltages except DCIN starts changing abnormally (for example PQ37 Drain changing between 5-19V).
    Please give me some advice what to do? I can upload full schematics if needed and measure voltages in points you tell me. Also can record sound if that could shorten diagnosis.
    Regards!
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Re: Compaq CQ62 power problem
    first of all cq62 have three types of motherboards you asking for which one ?
    post here motherboard model number.
    • JaroTech
      • Mar 2015
      • 351
      Hi, I think this is the schematics you need.
      • savo.lekic
        • Mar 2013
        • 10
        • Montenegro
        Laptop model is CQ62-a20sm with AMD Athlon II P320 processor. Foxconn Motherboard, P/N: 01013TM00-575-G
        I think schematics @JaroTech posted are right for this board?
        • savo.lekic
          • Mar 2013
          • 10
          • Montenegro
          Also AC_OFF signal is 0V in working mode, and when component starts making noise it changes between 0-3V.
          • savo.lekic
            • Mar 2013
            • 10
            • Montenegro
            Anyone have idea what could cause problem?
            • khaahk
              • Dec 2013
              • 756
              • Estonia
              With battery or without? Work from only battery the same behaviour? Charging battery ok without computer turned on?
              • savo.lekic
                • Mar 2013
                • 10
                • Montenegro
                With only battery it is not making clicking sound, and can be used normally. Also it is charging batery. in windows for long time it is saying that is not charging becouse battery is bad, but orange LED is on next to AC plug. One more thing, PC must not be on to make that clicking sound, so it must be something in charging circuit gone bad.
                PC works ok with battery, but board is doing same thing "pluging" in and out AC adaptor. When I plug battery in one capacitor is making noise and voltage on PCE20 is varying between 19.18V and 19.26V in loop while making noise. Not shure if noise is coming from this capacitor. When battery is out there is no noise, but just clicking sound after some time.
                When it is making "click" noise there is no +5V on PCE18 (page 32.). Maye that can be usefull, as I think some component on page 31. is bad...
                • Djosla
                  • Dec 2012
                  • 246
                  • Montenegro
                  You hear clicking of inductors most likely due to mosfet leaking...
                  When you pull out the battery,so that the laptop is only on adapter ,do you hear clicking...?
                  What are voltages in non working mode on :
                  +VBAT rail
                  ACIN,ACOK on MAX8731 ic
                  PQ55 drain
                  PQ38 gate
                  Acin needs to be low in order to have acok high to drive that transistor...Something could be wrong with internal comparator...
                  8731 is most likely culprit here,if you have it try to change it...if doesn`twork after replacement we will help you to diagnose it further...
                  A dje si Savo
                  • savo.lekic
                    • Mar 2013
                    • 10
                    • Montenegro
                    Ok. I will measure all voltages later and post it here.
                    Hahaa, a dje si ti Djosla!!!
                      HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:44 PM
                      HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                      This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                      HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                      This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                      09-12-2024, 03:36 PM
                      HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-12-2024, 03:30 PM
                      HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                      This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
