Acer Aspire One No Power
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hello i have a problem with acer aspire one 722.
    The gate of the p-channel mosfet is high and no voltage measured on drain.
    but the mosfet is good.. please help
    i attached the schem for other info ..
  • angel-boy
    • 550
    • Romania
    Re: Acer Aspire One No Power
    You have a short after mosfet that is why you have low vontage on pin 4.
    Your gate is 19v, and to open should be ~25-28v.
    Check with a laborator power supply, give like 1-2v and see how many amps "eating"
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      connect to a dc bench ps. take note of the voltage reading and the amps.
      then remove or place a jumper from source to drain of the fet in question, inject voltage from a dc bench setting lower than 1 volt also start from lower amp. find the one thats heating up while feeding supply from dc bench. if none found on the initial settings, try adding more amps gradually while looking for the culprit.
      without a dc bench ps, check coils which id shorted to ground. also check the output of the fet (19v rail) if shorted to ground. if coils found, remove the coil and check the FETs and ceramic capacitors on that section.
      hope this helps
      • khaahk
        • Dec 2013
        • 765
        • Estonia
        isl6251 pin2 voltage is?
        • ry x hunter
          • Jun 2013
          • 184
          • philippines
          0.7 volts sir
          • khaahk
            • Dec 2013
            • 765
            • Estonia
            Check pr24 and pr28 resistances. If they are ok - PU2 might be the cause.
              ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
              This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
              09-12-2024, 03:28 PM
              ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
              This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
              This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-06-2024, 05:27 AM
            • ithe
              Acer Aspire V5 571P 6499 power on but no display or no access to BIOS
              by ithe
              I am using this Acer Aspire V5 571P 6499 laptop for a long time. Laptop does powers on, but no display after properly shutdown while in its last working condition.
              Laptop model - Acer Aspire V5 571P 6499
              MoBo - Husk MB 11309-4M 48.4TU05.04M
              HW config. i5, 4 GB RAM,250GB SSD, Windows 10 OS
              status when laptop turned on
              no display no logo no BIOS access
              status - power led on, charging led (when power adaptor connected), led on power switch glow when power is on.
              fan spins and stops for a minute and again start spinning....
              10-31-2023, 01:59 PM
              Acer Aspire LAPTOP ASPIRE 5 A517-52-58VS Notebook 5 Specification for Upgrade or Repair
              This specification for the Acer Aspire LAPTOP ASPIRE 5 A517-52-58VS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LAPTOP ASPIRE 5 A517-52-58VS boardview and LAPTOP ASPIRE 5 A517-52-58VS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-07-2024, 05:50 AM
