Re: new70 5891p motherboard acer 5742 not charging
Hi, sorry guys i didnt see you already answered here.
I was about to check that IC. Problem is that im new to using the multimeter and i need to know how to connect the cables of the multimeter to check the voltages of the pins. I assume one cable needs to touch the pins, but what does the other cable need to touch?
If you can answer here you can ignore my post from the other thread.
Edit: how do i know which numbers you mention correspond to which pins of the IC?
HI,
so i found out i can use any place where a screw driver goes in as ground.
Here are the results from the faulty mainboard:
1. 0
2. 3.22
3. 0
4. 0
5. 7.4
6. 3.15
7. 4.8
8. 18.9
I got a healthy mainboard here so i checked there too:
1. 3.2
2. 3.2
3. 3.6
4. 0
5. 7.6
6. 3.16
7. 4.8
8. 18.9
What does this mean? I already tried to clean up a bit where i think there was some kind of liquid since i read on other boards that some people that helped. But it didnt in my case.
hello mr:samirabi.....ac mode not chariging solution..is 1st you shoud check protection circuit is vin >to PQ 61 MOSFET >THEN CHECK PQ62 HERE VOLTAGE WILL PRESET AFTER CHECK PR351 THIS IS POWER SRC CHECK HERE 19 VOLT AFTER YOU CHECK SRC TO BATTERY PATHE
Sorry for pushing this one up, can anyone can tell me what else i need to do to identify the faulty part(s)? I could desolder parts from the other mainboard and resolder to this one if needed.
