asus k54c, no power to processor when processor attached
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3608
    • slovakia
    have this asus k54c that have no power to processor when attached, but without processor 1,11V is ok. with processor have 19ohm resistance on coil.
  • HarryPK
    • Mar 2014
    • 210
    • barabai
    Re: asus k54c, no power to processor when processor attached
    Maybe bad prosessor,
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      19ohm is not totally bad with cpu attached , usually is around 26 29ohm but 19ohm is not bad at all as well .
      IF cpu once attached you loose connection , chek all the fets for all phases on the cpu , you must have some bad or even bad tantalum caps , in last case after cheking that all are good i would replace the CPU core ic
      post to us the results
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3608
        • slovakia
        Solved. just flashed bios.
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          ~ good
          • sasser
            • Dec 2012
            • 364
            • Malaysia
            I heard and from my experience asus laptop got problem with bios. Also i solved problem vivobook s400c just with flash new bios .the qlue is after 19v ,5v 3,v is presented and psu read 1.900a .
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              did u get MiniPro? use it to reprogram the eeprom
