China 13.3" netbook (Allview D425) backlight issues
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    A friend of mine bought this p̶i̶l̶e̶ ̶o̶f̶ ̶t̶u̶r̶d̶ netbook for parts, but he then decided he wants it fixed. It's got an Atom D425, 2GB DDR3 and a 320GB HDD which got swapped to a 32GB SSD (China's finest too, of course).
    The original issue was odd-coloured display with lots of horizontal lines striking thru it. Taking it apart revealed 2 bent pins in the LVDS connector. Someone's been here before and attempted to do something. Likely they tried to pull that wifi cable that was hanging out the hinge back in place. Easy fix.
    Now another issue has surfaced, namely the backlight. It will work fine for a few seconds to a minute, then start strobing like crazy then finally settle to a dim level, only strobing occasionally. Brightness controls will still work, just that it's "dim" to "off" instead of "bright" to "dim". Unplugging and plugging it back in makes it come back, then it does the same thing. Also the backlight will either not come on at all on battery power, or it'll work for a few seconds after it's unplugged, then turn off and stay off.
    My first impression to the construction of this thing was positive, it's cheap, but better than i expected. I'll take it apart again tomorrow and see what i find.
    A working TV? How boring!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: China 13.3" netbook (Allview D425) backlight issues
    Fixed. Loose LVDS cable. That connector it plugs in is absolute garbage.
    Anyway. I like the thing so much i might even get one for myself as they're dirt cheap. There is potential for quite a bit of modding inside.
    One thing that i don't like is the battery life - not because the battery is crap, but there have been exactly zero f***s given for power management in this netbook. The Atom CPU always runs at nominal clock and voltage, no reduction is possible via BIOS or software. Hence why the large copper cooling plate most likely... At least there is working overtemperature protection.
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      Good job. I have similar problem with Asus Lamborghini with LED backlight, haven't fixed it so far. Too lazy spend more hours on it.. LVDS cable changed, power on lvds conector seems to be ok, but have no other 12,1" 30-pin lcd screen for trying to change, so it's undone for that moment.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Played with it some more. Turns out the Atom D425 is a "nettop" (small desktop) processor, not a mobile one. It has higher TDP and lacks of support for Speedstep and EIST, so this is a processor limitation not the designers of this board being lazy. Since this is a generic unit, i wonder if an upgrade of the BGA processor will work. I have the stencil for it so maybe i will try when i get mine.
        This Atom D425 is a single core processor with HT, there is also the D525 which is a dual core with HT, with just 13W consumption as opposed to 10W. Then there is the N series, which has the "mobile" counterparts with lower TDP.
        I have also replaced the wireless card, Broadcom BCM4322 with a Realtek RTL8723AE. Previously the wireless range was all of 5 meters. With 3 bars of signal it dropped the connection... Now it's much better, i can walk around the place with it no problem. And i got free Bluetooth too as it is a combo card. It still feels like it could use the second antenna though (it only has one).
        I am going to be keeping this WLAN/BT card though, i'm not throwing that in for free.
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          how much is this cinease netbook?
          and 13.3 is big to be called netbook, almost a notebook
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Well they call it a "Note Book". But it has netbook specs so i call it a netbook. It was ~$280 new in 2011, now you can find it for $80-$100 used in good shape.
            What i really like about it is the screen. It has 1280x800 resolution and very good viewing angles. It is a TN panel but a very good one. Horizontal viewing angles are almost 180 deg! A $2500 Sony Vaio i worked on a couple months ago had a worse screen than this. It also weighs just 1.4kg.
              MSI CreatorPro M16 B13VI-887BE Netbook M16 Specification for Upgrade or Repair
              This specification for the MSI CreatorPro M16 B13VI-887BE Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the M16 B13VI-887BE boardview and M16 B13VI-887BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 07:19 AM
              MSI CreatorPro M16 B13VJ-882BE Netbook M16 Specification for Upgrade or Repair
              This specification for the MSI CreatorPro M16 B13VJ-882BE Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the M16 B13VJ-882BE boardview and M16 B13VJ-882BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              Acer Predator PT516-52s-79K1 Netbook Triton 500 SE Specification for Upgrade or Repair
              This specification for the Acer Predator PT516-52s-79K1 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT516-52s-79K1 boardview and PT516-52s-79K1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
              This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
              Acer Swift SFG14-71-51JU Netbook Specification for Upgrade or Repair
              This specification for the Acer Swift SFG14-71-51JU Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SFG14-71-51JU boardview and SFG14-71-51JU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
