What is S0,S1,S3,S4,S5 State
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    Hi boss,, I would like to know in a simple Explanation About All power state.. cause im confusing everytime i read a schematic diagramm. thanks
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: What is S0,S1,S3,S4,S5 State
    I'm assuming you are talking about computer systems.
    If so, I found this:
    https://software.intel.com/en-us/blo...r-states-s0-s5
    Muh-soggy-knee
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      its a resumed way , of the states , alltough there is deeper issue on the states for you can follow problem on motherboard , eahc state as mentioned on intel page , will carry on with a following step/order asked by the KBC , you should read about computer architecture you will find very usefull info altough somethimes a bit complicated that requires more study on outher areas
      • Sofian75
        Dell Inspiron 5502 i7 C-state Crash
        by Sofian75
        Turning off C-State in the bios makes the laptop works fine, but with C-State turned on the laptop will crash quickly once Windows has booted.
        What is managing C-State on the hardware level? What should I check?...
        09-02-2025, 08:50 AM
      • sc84647
        HP Elitebook 840 G3 - "Machine is not in committed state"
        by sc84647
        Hi
        I have an EliteBook 840 G3 that boots with "Machine is not in committed state!", the system info is correct when displayed in the BIOS screen:
        Serial Number : 5CG6481F5D
        Product Number : L3C65AV
        Description : HP EliteBook 840 G3
        I've tried using the BiosConfigUtility.exe from HP BCU (SP143621) which says MPM is in Lock state, and if I try changing that using that tool I get:
        <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access Denied" returnCode="6">
        <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
        02-11-2024, 08:27 AM
      • speggio91
        820-00165 no greenlight in S0 state
        by speggio91
        I've started to practise more on macbooks air board, I've got a bunch of defective ones, to see if I can gain some more knowledge.
        I've been focused on a water damaged board of an 2017 Air.
        Someone else already worked on it, the SMC has been reflowed plus some minor reflows around the board.
        I've reached a dead end but I improved the state of the board.
        Initially it was no power, no green light, no fan spin, stuck at S5 state.
        After replacing some components (U7090, Q5500, Q7430, C7432, Q7630, U1950, R6115, R6116,...
        11-19-2023, 09:56 AM
      • hotgly
        Surface Pro 9, i5 version, lost touch on screen after upgrading hard drive, and ISH Power State shows Disabled
        by hotgly
        After upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
        The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
        I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
        Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
        Serial number: 0F00S2Y22353BF
        Intel(R) ME Code Versions:
        BIOS Version 12.200.143
        MEI Driver...
        05-15-2024, 02:20 PM
      • valente222
        Help problem lenovo yoga 500 lt41 state vegetal plt_rts# off
        by valente222
        I have a Lenovo Yoga 500-14IBD LT41 laptop with power-on issues. It turns on, reacts to the 3.3v button. Its consumption is only 37mA, in the OFF state it consumes 8mA. remains in a vegetable state. The measures I have taken are:
        AC_PRESENT:3.3V
        ECRST# : 3.3V
        LID_CLOSE# : 3.3V
        1D05V_VTT : 1.05V
        RTC_RST#:3.3V
        5V_S5: 5V
        3D3V_PWR: 3.3V
        1D05V_LX : 1.05V
        1D35V_S3 :1.35V it ram
        VCC_CORE : 0V
        PLT_RTS: 0V
        OSCILLATORS ALL OK
        What other measurements can I take to check that pch if it is healthy?...
        05-24-2023, 04:50 PM
