EQ=DK equivalent IC
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    EQ=DK equivalent IC
    what is the equivalent IC of EQ=DK.
    please advice.
  • sparker1
    • Sep 2011
    • 343
    Re: EQ=DK equivalent IC
    RT8223MGQW. I can see them here - http://www.aliexpress.com/item/5pcs-...263768557.html
    • dycc
      Vision
      • Nov 2011
      • 625
      • Côte d'Ivoire
      https://www.badcaps.net/forum/showth...hlight=richtek
      • sparker1
        • Sep 2011
        • 343
        That should help everybody.
        • kuldeep
          • Sep 2013
          • 30
          • india
          IC EQ=DK mean RT9513GQW
          • masud
            • Jul 2011
            • 317
            • Bangladesh
            thanks a lot
            • masud
              • Jul 2011
              • 317
              • Bangladesh
              i m little bit confused.
              in the richtek marking information i found eq=rt9513gqw and rt8223m both.
              which one is right.
              what is the way to find the equvalent chip like EQ=DK. should i consider the first part (EQ) only? or have to consider dk also.
              please advice.
              • chazzo
                CH341 programmer advice, including jumpers seemingly reversed
                by chazzo
                I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                10-12-2025, 08:15 AM
              • Jidis
                Need T-Con Advice (Vizio P602ui-B3)
                by Jidis
                I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                09-22-2025, 05:10 PM
              • zlr8r
                Advice on newer EC chip programming eg. MEC5107-LJ BGA
                by zlr8r
                Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                09-16-2025, 09:54 AM
              • karlox
                IC UP9002p "equivalent"
                by karlox
                Good evening, colleagues.
                Does anyone know an equivalent or a compatible replacement for the uP9002P IC (power controller)? Alternatively, does it come under any other marking or code on different boards?
                Any insight or cross-reference would be greatly appreciated. Thank you in advance!
                09-01-2025, 08:43 PM
              • peter_wheat
                Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
                by peter_wheat
                Hi All,
                I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing...
                08-28-2025, 02:03 PM
