Toshiba C660 +CPU_CORE not found.
    Hello frnd, How are you all. I have a problem with toshiba c660. this laptop power on but cpu core voltage is missing.
    some important pin voltage given below.
    Pin 23 VIN= 18v
    Pin 22 VDD= 5V
    Pin 7 VR_On=3.3V
    Pin 31 VDDP= 5V
    So that i have change ISl95831 but same cpu core not found.
    Please suggest me what can i do, Please........
    Schematic Attached here
    Re: Toshiba C660 +CPU_CORE not found.
    why do u change ic? no diagnostic in front of changing?
    wanna change all of conponents on board to find some bad?
      Thank you for reply but I have check and not found any bad component, so that i change ic.
        anyone please?
          ugate1,2?
          lgate1,2?
          ugateg,lgateg?
            There is no voltage found in this ugageg, lgateg, ugate1 ugate2 lgate1 lgate2
              Check the VR_ON and r u checked 1.05vs_VCCP and VCCA that are normal?checked the pwrgood of these.
                VR_ON is 3.3, But another voltage not available.
                I need power sequence for it.
                  you have it !
                  diagram block on page 3 and
                  Voltage Rails on page 4 you can see the stage in every rail
                  S5 to S0 until every voltage its UP
                    Hello frnd, How are you all. I have a problem this board Toshiba c660 board. problem cpu core UGATE1 Mosfet will short. when i will press the power switch UGATE Mosfet will short ... alredy chenge also mosfet and ic . but same problem..please help me...
