Acer AOD 270 Shorted with Pictures please help
  • tomrush
    • Nov 2014
    • 20
    • Philippines
    i have acer netbook shorted board. i tried to follow the schematic until i came to a resistor i remove and its not anymore shorted. i remove the next mosfets after the resistor thinking its shorted but still problem persists. is there a possibility that the PU2 chip is the one shorted? please help me i have attach image and the schema for reference.
    i'm still new to board repair thank you
    i put red circle around the removed resistor
  • tomrush
    • Nov 2014
    • 20
    • Philippines
    Re: Acer AOD 270 Shorted with Pictures please help
    everytime i put back this resistor PR133 no power come in. i remove all component after this the resistor the PQ40 but still shorted. is it possible that this resistor? how to test if shorted and what is the resistance? what i only know is resistor is bad if open or no resistance. thank you please help me i'm still a beginner
    • khaahk
      • Dec 2013
      • 756
      • Estonia
      Measure resistance after PR133 (if you have it removed) relative to GND. If it is small (some ohms), then you have short in VIN, this could be all over the board. Then use lab power supply to find the short (of course if you have one).
      • tomrush
        • Nov 2014
        • 20
        • Philippines
        yes there is small ohms i measured. as you said sir there is a short in VIN. thank you so much...
        i want to know where will i start checking the short. are there common part of board that get easily shorted. what does a lab power supply look like? do i need to have this sir?
        thank you for answering my first question
        • Ramee
          • Jul 2014
          • 218
          • Israel
          This is what you need, adjustable power supply. You can get from here.
          http://www.aliexpress.com/item/Free-...668592085.html
          • tomrush
            • Nov 2014
            • 20
            • Philippines
            i have ordered this adjustable power supply from our local store. hope to have it in a week.
            sir ramee & sir khaahk i will order this power supply to trace shorted component, right? but while i'm waiting can i trace the shorted component. can this smart tweezer help me to trace the shorted component? if i can, what common component get shorted. i appreciate your help.
            • khaahk
              • Dec 2013
              • 756
              • Estonia
              Capacitor is the most likely component to fail. As they are all parallel, tweezers will show short everywhere. You will have to remove them one at a time to measure. Visual inspection under microscope sometimes helps.
              • Ramee
                • Jul 2014
                • 218
                • Israel
                @tomrush>> we are in boat, still learning how to test components.
                First, learn how to feel the heat by touching components while charger is pluggd in.
                Second, if you find something gettin hot, like cap, check for resistance or remove it
                from board to test it.
                About testing mosfet, go to youtube.
                • tomrush
                  • Nov 2014
                  • 20
                  • Philippines
                  thanks for the response sir. i'm gone for few days and finally got this avr of mine. i'm trying to practice to touch components to see if there is a heat. i found one mosfet overheating. i replaced it and the power is on yet no display. i'm in progress now trying to follow visual instructions from youtube. but while doing this does this little ceramic capacitors really get easily shorted because it's really pain in the ass to remove them one by one. but i appreciate if this is really the only solution.
                  • reessi
                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                    by reessi
                    Hello:
                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                    I started on the ACER:
                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                    10-29-2024, 11:31 AM
                    09-06-2024, 05:27 AM
                    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-07-2024, 05:00 AM
                    Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                    This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                    This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 04:10 AM
