how to start BQ24725 on Sony PCG-61714m
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    have another of this laptop charger IC that not starting system, not charging.
    ACDET - 3,3V
    VCC- 19V
    REGN- 6V
    no ACOK signal and ACDRV is about 1V. if i inject 19V to ACDRV after resistor, the system works but no battery and no charging
    i changed this BQ ic but nothing changed.
    have somebody schematic for this laptop or some other laptop with this chager ic?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: how to start BQ24725 on Sony PCG-61714m
    have some of this ic in laptops and always the same problem. somebody must have known how to start it
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      ok. there are diode that are connected to ACDET signal and goes to i dont know but this side of diode have 60ohm to ground and lowering my ACDET voltage to 0.6V. when i remove the diode the ACDET signal is ok-2,6V/must be max 3.05/ and system is working but not detect battery and not charge.
      have anybody some clue where is connected that diode that one side is on ACDET and i dont know where is connected.?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        and i forgot the mb code is mbx-240
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
          09-06-2024, 05:30 AM
          Sony VAIO VPCEB4M1E/WI Notebook E Specification for Upgrade or Repair
          This specification for the Sony VAIO VPCEB4M1E/WI Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEB4M1E/WI boardview and VPCEB4M1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
