NVIDIA GeForce GT 1030 Schematic & Board View
    The GeForce GT 1030 was an entry-level graphics card by NVIDIA, launched on May 17th, 2017. Built on the 14 nm process, and based on the GP108 graphics processor, in its GP108-300-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GT 1030. The GP108 graphics processor is a relatively small chip with a die area of only 74 mm² and 1,800 million transistors. It features 384 shading units, 24 texture mapping units, and 16 ROPs. NVIDIA has paired 2,048 MB GDDR5 memory with the GeForce GT 1030, which are connected using a 64-bit memory interface. The GPU is operating at a frequency of 1228 MHz, which can be boosted up to 1468 MHz, memory is running at 1502 MHz (6 Gbps effective).
    Being a single-slot card, the NVIDIA GeForce GT 1030 does not require any additional power connector, its power draw is rated at 30 W maximum. Display outputs include: 1x DVI, 1x HDMI 2.0. GeForce GT 1030 is connected to the rest of the system using a PCI-Express 3.0 x4 interface. The card's dimensions are 145 mm x 69 mm x 18 mm, and it features a single-slot cooling solution.​
    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
    10-02-2024, 08:52 AM
    NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
    The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
    10-02-2024, 07:51 AM
    NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
    The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
    10-01-2024, 01:54 PM
    NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
    The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
    10-02-2024, 08:57 AM
    NVIDIA GeForce RTX 3070 Schematic & Board View
    The GeForce RTX 3070 is a high-end graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA104 graphics processor, in its GA104-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3070. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA104 graphics processor is a large chip with a die area of 392 mm² and 17,400 million...
    10-02-2024, 08:48 AM
