Lenovo Y540-15IRH
  • zyzutopboss
    • Sep 2025
    • 4
    • Romania
    Lenovo Y540-15IRH
    hello, I have a lenovo legion y540 (nm-c221 rev 2.0), it suddenly turned off and then started to restart continuously, I reprogrammed the bios. After the reprogramming, the fans turned on for 5 seconds and then it turned off completely. The PU601 started to heat up and I discovered that there was an internal short in the ITE so I ordered a new one and put it on the board, but the laptop still doesn't give any sign, it doesn't start. I also read here on the forum that the IT8226E-192 on this model rewrites itself, is it true or do I have to rewrite it? I don't know what else to do with it...
    Help me, please 🥺
  • ERRA
    • Sep 2025
    • 35
    • Morocco
    Help me, please 🥺
    Better to program the i/o
    • zyzutopboss
      • Sep 2025
      • 4
      • Romania
      ok, so does the new IT8226E need to be programmed? I checked the continuity on pin 11 (VCC) with a multimeter and I have 460 mV, but if I power it with the laptop, the voltage is 0.
      Can you help me with a .bin file for this laptop model?
      • ERRA
        • Sep 2025
        • 35
        • Morocco
        Do you get 3V on that vcc line when power button is pressed??
        • zyzutopboss
          • Sep 2025
          • 4
          • Romania
          No. Noting happens when I press the power button
          edit:
          I'll check again when I get home and write to you.
          • zyzutopboss
            • Sep 2025
            • 4
            • Romania
            I checked again and I don't have 3V voltage when I press the power button. So is it from ITE that it is not programmed?
            • ERRA
              • Sep 2025
              • 35
              • Morocco
              You should have the 3VS , no need to waste time programming the the EC if that 3vs is missing
              widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
