Sony vaio , MBX-224 m960 destroyed by another store !!
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Hey guys , received a sony vaio that came frmo another store , the client mentioned to me , that the problem with the machine was random shutdown ( since its a recent board with HM nb/sb chip , usually this cause of random shutdown is due to this bga ) but in the outher store , i think they lift 1/5 of the components on board , and it left the store without even turning on .
    I've cheked that 19 volts line was damaged , and really not passing to many spots on board , so fixed the 19 volts line , and now got 19 volts everywere like it should .Cheked also having 3.3 and 5 volts , and it turned on , but turning off after few seconds without displaying any kind of image at all ..but not turning on anymore , even that pwrbton drop to 0 when pressed . (alltough pwrbton on the nuvoton is at 1.60 and nothing happen.
    Cheked SN0608098R and seems fine for exception to pin 14 EN_1 should be 5 volts but have there 3.2 , just the same value as EN_2 (+3v)
    i will add values for pinnout more in the bottom of this post .
    So i reflashed the EC with a good dump for this exact board model , and it started to turn on , but there was no voltage to the cpuvcore coils .. 0 volts there , but meanwhile i had 1.5 for ddr and 0.98 for gpu coil and gpu was getting hot . then nothing else.
    So after does try really didnt made anything to it , but stoped working (not turning on even that all voltages are present on s3 .
    so returned to the previous original dump from this board to see any changes but no changes as well ..
    so start cheking nuvoton , and usually s3 pins are giving correct voltages , alltough i even have the bloody VDD at pin 4 . so something is not allowig the board to not turn on . after a very carefully chek , at CN30 ii noticed there was a bit of solder merging pin 6 to pin 7 (MB_FLASH_EN - CARD_INSERT)( EXTERNAL SPI ROM INTERFACE (EC)) .
    so lets for gor for some voltages
    SN0608098R pinout :
    1 - 1.97v
    2 - 0
    3 - 5
    4 - 3.28
    5 - 3.28
    6 - 19.82
    7 - 5.02
    8 - 0
    9 - 5
    10 - 5
    11 - 0
    12 - 0.88
    13 - 3.32
    14 - 3.20
    15 - 5.02
    16 - 5.02
    17 - 10.06
    18 - 0
    19 - 0
    20 - 5
    21 - 2.26
    22 - 0
    23 - 0
    24 - 8.34
    25 - 3.30
    26 - 3.30
    27 - 3.21
    28 - 0.86
    29 - 0
    30 - 3.30
    31 - 0.79
    32 - 5
    NUVOTON 783
    RSMRST 3.32 nothing happen in this moment when pressed on off btn
    VDD VCC and AVCC all with 3.32 v
    ACIN_EC 3.32v
    ALW_PWRGD 3.32v
    PWRBTN# 1.62v
    ALW_ON - 3.31v
    INST_ON_SW# 0.88v
    ECRST# 3.28v
    any outher measures need , just request.
    schematic is on the attachement
    also another thing i noticed , somethimes voltage on coil 3.3 and 5 , simply stay at 0 (for no aparent reason , without touching it , but pressing the on off button , they come back to good values 3.3 and 5 !
    Im tired of this board and would be good a help here.
    cheers guys
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: Sony vaio , MBX-224 m960 destroyed by another store !!
    once again it all indicates its this bloody intel chipset .... on button come from this asshole .. and for the complain of the client for the random shutdowns... bloody intel !!!
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3593
      • slovakia
      PWRBTN# 1.62v
      way low
      • highpulse
        i hate HP
        • May 2013
        • 1488
        • portugal
        yes this value is provided by HM55 ... this chipset are really a shame by intel .. so poor quality , major part of the latest machines i got here usually afyer hm replace they are ok . incredible !! they are passing AMD and nvidia very fast with they S#$% chipset.
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          chekig well , this value is provided by the nuvoton itself , and pass it to HM55 ,
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            also now i see another diference with the bios files , with the original dump it turn on and shut off the led after 2 sec , with the Dump downloaded for this board , led stay on , but there is no activity on board.
            if someone have some dumps for this to test it out with other dumps , would be nice ,
            M960_mp_MB
            8layer MBX-224
            REV 1.1
            nuvoton 783laodx
            EC rom winbond winbond 25x10bv
            main winbond 25q32bv
            download my dumps at 1bios.ru , but does what i've mentioned above
            • atsio
              • Oct 2013
              • 819
              • Greece
              Please upload the original dumps
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                original dumps aas requested
                • tata123
                  • Nov 2013
                  • 104
                  the most problems of this type is KBC (EC) it could be also a broken Windbond chip....
                  • rajeshkumar
                    • Oct 2014
                    • 44
                    • india
                    Re: Sony vaio , MBX-224 m960 pROBLEMATIC ISSUES
                    what is the hm type
                    • fixfixit
                      • Jun 2010
                      • 14
                      • Sri Lanka
                      Both EC and Main bios dumps are working great, Thanks for the upload
                      • Pragmatiko
                        • Jul 2013
                        • 468
                        • IT
                        M960_mp_MB
                        8layer MBX-224
                        REV 1.1
                        nuvoton 783laodx
                        Asap go to office I will put the right bios. Just give me right model number.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3593
                          • slovakia
                          PWRBTN goes to KBC, replace and flash it
                          • Pascal Komlassan
                            • Jan 2017
                            • 808
                            • TOGO
                              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:27 AM
                              Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                              This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                              Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                              This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                              09-06-2024, 05:30 AM
