HELP my Monitor display says: RGB No Input
+ More Options
Posts
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Hi all
    Normally I shutdown my PC at night. When I tried to start up this morning the normal statup sounds are audible and I see the LED flickering implying all is OK for the hard drive do it's thing.
    However, the standby orange LED on the monitor does not go green to turn on the monitor.and show video. I think the monitor is OK since at plugin and when the power button is pressed the backlights come on and aRGB No Input message comes up then after afew secons the LED goes back orange in Stand by mode.
    I am not sure if it is the turn on and video signals are not being output from the tower.
    What must I do to troubleshoot??
  • addytzu123
    • Mar 2013
    • 54
    • ROMANIA
    Re: HELP my Monitor display says: RGB No Input
    First - might sound stupid, but reconnect your monitor cable both on the monitor side and on the PC side.
    Two - narrow down the issue, PC/Video card problem ?/ Monitor cable issue? / Monitor itself issue? so test your monitor on a different PC.
    Third - report your findings and we shall continue from there
    In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Thanks addytzu123 for your response. I had no computer over the weekend and so the first thing I am doing now is checking for aresponse via my work computer. OK so I got a next monitor cable and that gave the same symptom. I connected the monitor on another computer and it is working fine- ruled out monitor problem. I discovered after opening the CPU Tower and the HDD is getting power and sounds to be working but nothing. So I want to think the hard drive is OK. I noticed the video card fan is running and perhaps may be OK. The PSU seems to be OK, too.
      My final gues is, could it be the Mother Board??
      BTW it is an IDE system built in 2006 with Windows XP and MS office 2003. Perhaps it might be time for an upgrade but if I can fix this sytem I could keep it to read Schematics, copy CDs and DVDs and other non Internet stuff. Thanks
      • sunilnjarakkat
        • Dec 2013
        • 13
        • u.a.e
        Update monitor firmware
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          OK so I have determined the following pieces are working as I tested them on another computer:
          1. Monitor.
          2. HDD.
          3. 450W Power Supply.
          4. 4 x 1Gigs RAM cards.
          Unable to test:
          1. Video card
          2. Mother Board.
          Deduction:
          1. Main Chip defective on Mother Board.
          2. HDD getting power but unable to respond.
          3. Video card good.
          Decided:
          1. Recover information from HDD.
          2. Buy another sytem as this is an outdated IDE system using Windows XP and Office 2003.
          3. Time to go SATA with Windows 7 and Office 2013.
          4. Look for a sytem with a Solid State Hard Drive, Intel main chip with 8Gigs RAM
            by momaka
            03-15-2023, 10:17 PM
          • matthewmcconaughey
            I need help with my friend Sony GDM-FW900 24” CRT
            by matthewmcconaughey
            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
            1. It started with a bright and greenish picture upon starting a cold monitor.
            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
            05-16-2023, 03:15 PM
          • ugamazing
            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
            by ugamazing
            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
            04-10-2024, 08:06 AM
          • Rick_1234
            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
            by Rick_1234
            Good evening, gentlemen.
            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
            https://drive.google.com/file/d/1L6S...ew?usp=sharing
            Things I tried
            - Bought a new AC adapter thinking that was the problem but the problem...
            06-22-2024, 04:44 PM
          • sew333
            Pc shutdown, monitor flickered with no signal after 10 seconds
            by sew333
            My pc:
            10850K stock 4800mhz stock Kraken X73 good temps
            2x16 GB DDR4 GSKILL 3000mhz XMP
            Seasonic Tx-850 Ultra Titanium
            Gigabyte Rtx 3090 Gaming OC
            Aorus Z490 Pro Gaming
            1 TB SSD
            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
            Power...
            02-22-2022, 10:27 AM
