Precision 5550 LA-J191P No Power, Burnt ISL9538
  • swimllamaswim
    • May 2016
    • 25
    I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
    Here are the voltages measured at that chip:
Name:	PU1900 Voltages.png
    To note, DCIN at Pin 17 is low, fluctuates between 16.4 and 16.6v, and pins 1 2 and 3 are all low at 1v. I do not have any voltage on the main power rail.
    Where should I be looking next? Does anyone know if there may be a boardview available for these (or the XPS 9500/9510)? Doesn't seem like there is, but figured I'd ask!
  • mon2
    • Dec 2019
    • 14717
    What is the voltage to ground of +CHG_VIN_20V? (measure @ PD1900 - anode)
    • swimllamaswim
      • May 2016
      • 25
      That's at 0.395v
      • mon2
        • Dec 2019
        • 14717
        What is the voltage @ pin 17 on the charger IC? This diode is the adapter voltage. The other diode is the battery voltage to power the charger IC.
        • swimllamaswim
          • May 2016
          • 25
          That's at .4v on the dot.
          • mon2
            • Dec 2019
            • 14717
            What are the voltage to ground measurements for:
            TBT_VBUS1
            TBT_VBUS2
            TBT_VBUS3
            with the USB-C adapter connected?
            • swimllamaswim
              • May 2016
              • 25
              TBT_VBUS1
              TBT_VBUS2
              TBT_VBUS3
              All three are showing OL with adapter plugged in and powered.
              • mon2
                • Dec 2019
                • 14717
                Be sure you are in the DC volts scale on your meter. On a manual meter, the OL means the voltage being measured is over limit so select a higher scale.
                On USB-C power adapters, the power on default will be 5 volts and then the power delivery controller chip will negotiate a higher voltage to power the logic board. Often this is 20V.
                • swimllamaswim
                  • May 2016
                  • 25
                  Sorry, I think I misunderstood - I thought you meant measuring in diode mode, getting the voltage required.
                  Just the voltage readings are:
                  +CHG_VIN_20V: 20v
                  Pin 17: Fluctuates between 16.4 and 16.6
                  TBT_VBUS1: 20v
                  TBT_VBUS2: 20v
                  TBT_VBUS3: 5.04v
                  • mon2
                    • Dec 2019
                    • 14717
                    Then 20V must be reaching the diode @ PD1900? Or not?
                    • swimllamaswim
                      • May 2016
                      • 25
                      Yes, it is, CHG_VIN_20V was measured there.
                      • mon2
                        • Dec 2019
                        • 14717
                        But pin 17 (DCIN) fluctuates? This pin should be ~0v6 lower than CHG_VIN_20V voltage and should be stable.
                        • swimllamaswim
                          • May 2016
                          • 25
                          Yeah, it's fluctuating quite a bit. Seems to be slowly dropping over time, it's been sitting for ~20 minutes unplugged, when I saw this message I plugged it back in just to verify and it was at 20v right when I plugged it in, and dropped to mid 17v shortly after, and is now sitting between 16.8-17.2.
                          • mon2
                            • Dec 2019
                            • 14717
                            Remove all power. Meter in resistance mode. Measure the resistance across the resistor @ PR1907. Is this ~2 ohms? If not, it is defective. This is a point of failure.
                            Measure the resistance to ground of the DCIN pin # 17. Post each measurement.
                            • swimllamaswim
                              • May 2016
                              • 25
                              PR1907 is at 505 ohms, and once I cleared some trash off the board around it, I did notice it has a small burn hole on top of it. I'll see if I have one of those and get it replaced.
                              Pin 17 to ground is showing OL.
                              • mon2
                                • Dec 2019
                                • 14717
                                You can purchase these from Digikey /Mouser/Arrow. In a pinch, it can be bypassed for testing but understand that the dual diode may be the next guy to burn out if there is an excessive current draw.
                                • swimllamaswim
                                  • May 2016
                                  • 25
                                  I see in the schematic that it says "X01.16 change PR1907 from 2.2_1206_5% to 10_1206_5%", would it then be better to go ahead and put a 10ohm resistor there? I actually do have a few of those. I should have some 2.2ohm through holes somewhere I could use to test with, but I seem to have misplaced that box haha
                                  • mon2
                                    • Dec 2019
                                    • 14717
                                    Yes, 10R ohms is fine to use here.
                                    • swimllamaswim
                                      • May 2016
                                      • 25
                                      Okay, that brought Pin 17 back up to 19.84v solid, same as what I'm getting at PD1900. Still only getting 1v on pin 1-3 though.
                                      • mon2
                                        • Dec 2019
                                        • 14717
                                        Review the voltage to ground @ PL1901 (either side).
                                          DELL Precision 5550 Mobile workstation 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 5550 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5550 boardview and 5550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                          09-06-2024, 08:10 PM
