NEED A PICTURE - ASUS TUF A17 706N - DAONJXMBACO REV: C
  • khaahk
    • Dec 2013
    • 810
    • Estonia
    As there is nothing new to go on, the battery is communicating, the only thing for now is to check the first mosfets for short. If there was a short earlier on the board they might have suffered.
    • Pierro208
      • Dec 2023
      • 70
      • France
      I checked the input MOSFETs, they are good, I changed them anyway, and rechecked those of the charging circuit, no change, still no charging
      • mon2
        • 14659
        See your post # 6. With adapter AND battery, BATPRES# remains a non-zero voltage value?
        The '#' means the signal is an active LOW signal. When this line is LOW = 0v, then the battery IS present. With the posted measurements, the battery is not detected. Check the wire from the battery pack that is linked to BATPRES#.
        You can also take a piece of wire and short the BATPRES# line to ground and test again. This will force the charger IC to believe the battery is present.
        • Pierro208
          • Dec 2023
          • 70
          • France
          Thanks if I ground BATPRES with the battery and the charger, currently 1.2V it will force the system to recognize the battery, I am stuck on all bios updates, impossible to do without the presence of the battery, I wonder if the problem does not come from the EC chip?
          • mon2
            • 14659
            ?? Did you try the suggestion? Does the unit power up anymore?
            • Pierro208
              • Dec 2023
              • 70
              • France
              #26
              No, I'll try tomorrow and thank you.
              • Pierro208
                • Dec 2023
                • 70
                • France
                #27
                I just tested by connecting BATPRES to ground, no more starting and I removed the ground wire and no more starting either on battery or charger ????de
                • Polluxxiv
                  • Sep 2025
                  • Ghana
                  #28
                  Hello please can somone help me with the file or folder that I can use to erase bios?
                  • mon2
                    • 14659
                    Measure the voltage to ground on the charger IC for the following pins with only the adapter:
                    ACN
                    ACP
                    ACDET
                    REGN
                    ACDRV
                    VCC
                    BATPRES#
                    • Pierro208
                      • Dec 2023
                      • 70
                      • France
                      #30
                      ACN 20V ACP. 13.25V
                      ACDET 1.1mV
                      REGN. 6.0V
                      ACDRV. 26V
                      VCC. 20V
                      BATPRES#. 1.6mV
                      • mon2
                        • 14659
                        ACDET is too low. This voltage must be 2v4 or higher to detect the power adapter. Yet, acdrv is ok. Double check the ACDET measurement.
                        • Pierro208
                          • Dec 2023
                          • 70
                          • France
                          #32
                          I was wrong, you are right, I have 2.7V
                          • mon2
                            • 14659
                            Can you double check your ACN and ACP voltages to ground? Each should be similar in measurement. If not, the charger IC will turn off the DCin mosfets.
                            Carefully measure directly at the charger IC pins but only if your meter probes are the fine tipped versions. Do not proceed if the meter probes are too thick due to potential shorting. Red probe to charger IC; black to ground.
                            • Pierro208
                              • Dec 2023
                              • 70
                              • France
                              #34
                              I just checked, I have 20V on both, I have fine tip probes
                              • mon2
                                • 14659
                                These are good measurements for the points that have been measured.
                                Carefully measure the voltage to ground of each and every inductor on the board. Checking if there are voltages that are absent on the board. Do you have a boardview file for this model? Schematic will be a dream but rare to source for Asus models.
                                • Pierro208
                                  • Dec 2023
                                  • 70
                                  • France
                                  #36
                                  Regarding the boardview I have a model that is similar with I5, for me it is a Ryzen 5, regarding the measurements you can refer to message #6 and #12, #20 what is strange is that the PC starts if the battery is well charged and below 30% battery it does not start either on battery or charger, if anyone has an idea?
                                  • mon2
                                    • 14659
                                    Is the power adapter the OEM model for this unit? Adapter could be under rated.
                                    Do you have charging at all if booting with a pre-charged battery?
                                    • Pierro208
                                      • Dec 2023
                                      • 70
                                      • France
                                      #38
                                      Yes, everything is original, charger, battery and there is no charge, battery precharged or not, there is plenty of information at the beginning of the post, do not hesitate to look at them
                                      • mon2
                                        • 14659
                                        You have a 1v2 voltage on ACDET with only the battery (post #12). This is odd to me.
                                        Locate the VCC pin on the charger IC and you should have a dual common cathode diode (SOT23 package = 3 pins) nearby. Using only the battery, measure the voltage to ground on each pin of this dual diode. Share the measurements. Suspecting that this dual diode may be leaking.
                                        • Pierro208
                                          • Dec 2023
                                          • 70
                                          • France
                                          #40
                                          Je n’ai pas cette diode double, j’ai cherché sur la carte mère, je ne la trouve pas, était-il possible d’avoir un autre composant, j’ai testé les diodes autour de la puce et elles sont bonnes, une photo des BQ254800 de la carte mère.
