DAH98NMB8C0 REV:C HF BATTERY LOGO DISPLAY
  • Andri15
    • Jul 2024
    • 39
    • indonesia
    Has anyone ever experienced a case like this? Or does anyone have a solution for this?
  • mon2
    • Dec 2019
    • 14316
    Battery is low in voltage and is discharged. Attach the suitable power adapter to charge the battery.
    Does the unit power up with the power adapter connected?
    • Andri15
      • Jul 2024
      • 39
      • indonesia
      that's the condition when the power adapter is connected
      • mon2
        • Dec 2019
        • 14316
        Then the power path is not making it to the main power rail.
        Do you have a schematic for your model?
        • Andri15
          • Jul 2024
          • 39
          • indonesia
          CAN YOU GIVE ME A SCHEMATIC OR BOARDVIEW I DON'T HAVE IT
          • mon2
            • Dec 2019
            • 14316
            Not available.
            How is this unit powered? Is this a USB-C style of power adapter or a round barrel jack?
            Are you comfortable with opening up the unit and take measurements with a multi-meter? If not, the unit will have to be repaired by a local tech. What we need to do here is to trace the DCin power connector and follow this to the main power rail. Interested to know which charger IC is onboard. Then we can probably reverse engineer the design and fix the fault.
            • Andri15
              • Jul 2024
              • 39
              • indonesia
              It uses a type C jack, DCin power is already spread out but it's still like that
              CAN THIS BE FROM THE BATTERY IC? BQ25713
              • mon2
                • Dec 2019
                • 14316
                Yes - that is the battery charger IC.
                Reference the datasheet for the same:
                https://www.ti.com/lit/ds/symlink/bq...ouser.com%252F
                Meter in DC volts (30v scale or higher) mode.
                Carefully measure the voltage to ground of the following pins on the charger IC:
                REGN ; pin 28 - should be ~6volts if normal
                VBUS ; pin 1 - should be the adapter voltage and is used to power this charger IC
                Then remove all power. Meter in resistance mode. Disconnect the battery as well.
                Measure the resistance between the SRN & SRP pin directly on the charger IC. Again, no power to the board.
                We are checking if the full path resistance for this battery charging current sense loop is correct for the charger IC. Most likely, the logic board designer used this reference datasheet for their design so expecting to see ~20R ohms for this measurement.
                Click image for larger version  Name:	typical.png Views:	0 Size:	97.7 KB ID:	3698785
                • Andri15
                  • Jul 2024
                  • 39
                  • indonesia
                  yes it is 6v, but why does the screen always show the battery logo
                  • mon2
                    • Dec 2019
                    • 14316
                    This is because the battery is discharged and the adapter is either not detected or there is a fault in the battery charging circuit.
                    REGN @ 6v is a good start.
                    Share the SRN / SRP resistance measurements. Disconnect the adapter and battery before measuring this full path directly on the charger IC. If the resistance is not like the schematic then the charger IC believes there is a problem and will shut down the charging process.
                    • mon2
                      • Dec 2019
                      • 14316
                      Also measure the voltage to ground of the SYS pin on the charger ic.
                      This is the main power rail. What is the voltage?
                      • Andri15
                        • Jul 2024
                        • 39
                        • indonesia
                        for vsys pin i found it at 8volt
                        • Andri15
                          • Jul 2024
                          • 39
                          • indonesia
                          The results of my SRN/SRP resistance measurements found 19v
                          • mon2
                            • Dec 2019
                            • 14316
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • mkdj
                              ASUS X571 no power : battery issue?
                              by mkdj
                              Mark and model: ASUS X571
                              Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                              Tests already made:
                              - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                              - I have removed...
                              07-14-2025, 09:16 AM
                              DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                              This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
                              09-06-2024, 06:06 AM
                              DELL XPS 9380 Notebook 13 Specification for Upgrade or Repair
                              This specification for the DELL XPS 9380 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9380 boardview and 9380 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9380 Notebook...
                              09-06-2024, 08:55 AM
                              09-06-2024, 08:38 AM
