Minisforum MC560 DC in failure
  • grave_digga
    • Jan 2023
    Hi there. My name is Markus and this is my very first post here, so don't be to harsh on me. 😉
    I own a Minisforum MC560 that worked just fine. Some days ago something in the device gone nuclear and produced magic smoke. Here is a picture of the situation:
    Ignore the time stamp on the picture, i reseted my microscope a few days ago. Q32 is shorted and got so burned that it got really crusty. This is how it looks after a little cleanup. Q31 is an 8031 and it is just fine, i'll replace it anyway with a new one. The problem is Q32. I don't know what component this really is. Another 8031? Im could replace the components but i'm not really good at electronics to really know what component is needed there. I think Q32 is also a kind of Mosfet. I contacted Minisforum support. But they we're waisting my time, a few emails back and forth. "We couldn't provide you with the information you asked for". Thank you. This is a daughter board to the mainboard, F6CQW_IO-V30 2022 1013A. I found no schematics for the whole unit or for the daughter board. There are no shorted caps in the area, so i think it's "only" Q32 that's gone bang. Any suggestions what i need there? And sorry for my bad english, i'm german. 🙈
    After all of...
    07-13-2024, 08:14 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • ctroxtell
    Carrier HK50AA063 display controller common failure help
    by ctroxtell
    I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
    02-05-2025, 05:31 PM
