How to test ncp81382
  • khelane
    • Apr 2015
    • 172
    • xxxx
    ​Hello
    please help me. How can I check if this IC ncp81382 is healthy or not?
    The zbook 15 G3 had a problem with the CPU controller IC and the 5V part was connected, after replacing it it was fixed, but now I still don't have the CPU voltage output.
  • mon2
    • Dec 2019
    • 14666
    What is the resistance to ground of the cpu power rails? No power to the board during resistance checks.
    • khelane
      • Apr 2015
      • 172
      • xxxx
      PL47&PL49 : 3.1 Ohm
      PL48&PL50 : 4.1 Ohm
      The device would not turn on. After checking the two type c controllers, the device was burned, as well as the two USB ESD protection diodes. I removed all four, the problem of connecting the voltage input 19 was solved, but I had a connection in +5VDS. After checking the processor controller IC with the number NCP 81205. There was a connection on its pin 16. I removed this IC, the problem was solved, and then I replaced the IC. Now the device starts and the voltages are established except for the processor voltages. Separate graphics voltage is also generated.
      • mon2
        • Dec 2019
        • 14666
        What is the voltage of the pwm pin?
        • khelane
          • Apr 2015
          • 172
          • xxxx
          Problem solved
          Resistors PR 174 and PR 193 were replaced and the problem was solved.
          Now the VCORE voltage is established and the device shows an image after the BIOS program, but the inductors 48 and 50 do not have voltage.
          Now the device shows an image but the SSD and hard drive are not recognized and I am currently looking for the BIOS for the device to see if it is from the BIOS.
          This is the BIOS of the device itself
          • khelane
            • Apr 2015
            • 172
            • xxxx
            Can you fix the BIOS for me?
            APW50 LA-C381P REV 1A
            tnx
            • mon2
              • Dec 2019
              • 14666
              Post the same request inside the dedicated bios forum. See above. Someone there will be able to help.
              • khelane
                • Apr 2015
                • 172
                • xxxx
                • khelane
                  • Apr 2015
                  • 172
                  • xxxx
                  I requested the BIOS.
                  I got a BIOS that came with the image but gave a warning.
                  I accidentally faked the BIOS of the device itself and with that image came the image but it still gives two warnings.
                  I set the factory settings in the BIOS and restarted it but
                  it does not recognize the SSD and WLAN.
                  I also updated the BIOS to the latest version but these two components are still not recognized. While I can install Windows with the
                  HDD
                  SSD AND WLAN
                  tested and works.
                  By the way, I am still waiting for the BIOS that I requested in a separate thread.Click image for larger version
