Asusu vivo book not charging
  • koby058
    • Jan 2017
    • 382
    • israel
    Hi gentlemens,
    I have this vibo book that got a bit of water. After clean up the boarf. It works on adapter and work on battery, but it is not charging.
    I have checked first and second mosfet They look fine. Replaced 9241H to a new one but it is still not charging. Battery accept charge directly from power supply.
    Can you advice on things that i can check?
    Motherboard have no schematic available online.
  • mon2
    • Dec 2019
    • 14261
    Share the full measurements of the DC in mosfets. Recently repaired an HP with same issues and the fault was the first DCin mosfet.
    Remove all power. Meter in resistance mode.
    Test resistance across:
    source / drain
    source / gate
    gate / drain
    Post each measurement. Suspecting you have a bad mosfet.
    • koby058
      • Jan 2017
      • 382
      • israel
      first mosfet
      source / drain 290k
      source / gate 470k
      gate / drain 155m
      second mosfet
      source / drain 290k
      source / gate 400k
      gate / drain 2.5m
      both are p channle pk5b9ba
      • mon2
        • Dec 2019
        • 14261
        gate / drain 155m
        Is this correct or should be 155k ohms?
        • koby058
          • Jan 2017
          • 382
          • israel
          I see that the polarity of the multimeter matters when you change direction
          when i probe both mosfets where black prob on drain and red probe on gate
          igot 2.2M on both mosfets
          what do you think?
          • mon2
            • Dec 2019
            • 14261
            See attached. Connect both the power adapter and battery. Carefully measure the voltage to ground of the following pins (more later):
            ACOK
            DCIN
            Datasheet:
            • koby058
              • Jan 2017
              • 382
              • israel
              Sure
              ACOK is 2.99v
              DCIN is 18.79v
              • mon2
                • Dec 2019
                • 14261
                These voltages look ok.
                Remove all power. Meter in resistance mode. Measure the resistance between CSIP and CSIN pins. This is the battery charge current sense loop resistance path. Measure directly at the charger IC pins but without power to the board.
                • koby058
                  • Jan 2017
                  • 382
                  • israel
                  CSIP to CSIN is 2.5 ohms
                  • mon2
                    • Dec 2019
                    • 14261
                    The resistance looks to be in line. See the evaluation kit for the ISL9241 for guidance on what is most likely copied on your Asus motherboard.
                    What is the voltage to ground on each pin on the battery connector?
                    • koby058
                      • Jan 2017
                      • 382
                      • israel
                      Hi, I will only be there on sunday and i will check that.
                      I have found out that the laptop only works with battery connected and not charging
                      I am not sure if the laptop must have a working battery for it to work or it is indicating an issue
                      I will send the values next week
                      • koby058
                        • Jan 2017
                        • 382
                        • israel
                        So, when i measured the main power rail i saw the voltage spiking between 13v to 15v so i have figured it is a voltage regulation issue
                        checking all related mosfet, i found another 2 N channel mosfets and another small one that got a bit of the water damage on the back of the board.
                        replacing it solve the issue, thanks a lot for the help!
                          Samsung Galaxy Book Pro GALAXY BOOK PRO I5 8GB 15.6IN SLV Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Pro GALAXY BOOK PRO I5 8GB 15.6IN SLV Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GALAXY BOOK PRO I5 8GB 15.6IN SLV boardview and GALAXY BOOK PRO I5 8GB 15.6IN SLV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                          09-07-2024, 02:00 AM
                          Microsoft Surface Book Surface Book Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Book Surface Book Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book boardview and Surface Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 12:40 AM
                          Samsung Galaxy Book S Galaxy Book S Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book S Galaxy Book S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book S boardview and Galaxy Book S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 08:10 PM
                          Microsoft Surface Book Surface Book 2 Hybrid (2-in-1) 2 Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Book Surface Book 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 2 boardview and Surface Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 06:20 PM
