the idea is that I will and he will like to know and I think many will like to know or find out how or why is the chip blown. like a symptom a value something is missing and that's why the chip its bad.
you know? I will really like to know how to identify a bad PCH
"The lvds connector was pushed in reversed" . that way he have surely supply pch with 19V .
While checking for fysical faults, I found that due to the blow, PWR_SWIN#_3 was not connected to the power switch. I fixed it, but no change.
Also, when I connected the HDMI, the TV said ˝no signal˝ .When you unplug the connector and replug it, the screen turns black before he comes back with ˝no signal˝.
Just before he comes up, in the upper left corner, where normally the Post is written, you see very briefly ˝snow˝ like a tv without antenna. It passes so quickly I cannot take a picture.
Normally you got 19v on pin 25 to supply screen led . But at the time you reversed lvds cable the 19v went on pin 6 with is directly connected to pch lvds pin
I understand, but my way of thinking was different. The supplied voltage is on connector CN3000 pin 25, and if you stick in the lvds cable reversed, the supply of 19V is given to pin 6 of the cable, which will kill the lcd logic, but I don't see it return from there to PCH.
The cable connector was put in reversed, not the CN3000
i understand, but my way of thinking was different. The supplied voltage is on connector cn3000 pin 25, and if you stick in the lvds cable reversed, the supply of 19v is given to pin 6 of the cable, which will kill the lcd logic, but i don't see it return from there to pch.
The cable connector was put in reversed, not the cn3000
you are right . But short in the lcd logic will return back to pch .
Since it looks like the PCH is dead I stopped repairing this laptop. I do not have the equipment to replace the PCH and the investment to have it done is not worth it.
I thank everybody who participated in this thread for their time and effort.
