Toshiba L650 blown video?
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Toshiba L650 blown video?
    new pch don't waste time
    • dj_ricoh
      • 2073
      • uk
      the idea is that I will and he will like to know and I think many will like to know or find out how or why is the chip blown. like a symptom a value something is missing and that's why the chip its bad.
      you know? I will really like to know how to identify a bad PCH
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        "The lvds connector was pushed in reversed" . that way he have surely supply pch with 19V .
        • hansie55
          • Dec 2013
          • 254
          • Netherlands
          find u6500 and see the voltage ok?
          we need to identify everything and compare so we can conclude if actually the chipset its broken.
          do you have a lab psu?
          U6500
          pin 1 = 2,5V
          pin 2 = 5V
          pin 3 = 5V
          pin 4 = oV
          pin 5 = 0,2V
          pin 6 = 0V
          pin 7 = 0,8V
          pin 8,9,10,11,12 = 0V
          pin 13 = 4,41V
          pin 14,15 = 0,97V
          pin 17,18,19 = 0V
          pin 20,21 = 5V
          pin 23,24 = 0V
          pin 25 = 0,13V
          pin 26,27 = 1,07V
          pin 28,29 = 0V
          pin 30,31 = 1,05V
          pin 32 = 0V
          • hansie55
            • Dec 2013
            • 254
            • Netherlands
            While checking for fysical faults, I found that due to the blow, PWR_SWIN#_3 was not connected to the power switch. I fixed it, but no change.
            Also, when I connected the HDMI, the TV said ˝no signal˝ .When you unplug the connector and replug it, the screen turns black before he comes back with ˝no signal˝.
            Just before he comes up, in the upper left corner, where normally the Post is written, you see very briefly ˝snow˝ like a tv without antenna. It passes so quickly I cannot take a picture.
            • hansie55
              • Dec 2013
              • 254
              • Netherlands
              #26
              I am not sure about that, because the screen on the other end of the cable will be damaged, but I do not see a return to PCH?
              • dj_ricoh
                • 2073
                • uk
                #27
                plug everything like hdmi vga lcd and see the pins vid0 to vid6 pins26 ->32
                "pin 26,27 = 1,07V
                pin 28,29 = 0V
                pin 30,31 = 1,05V
                pin 32 = 0V"
                its trying to do something
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  #28
                  according to diagram reverse cable mean that you got 19V(pin 25) on pin 6 (LVDS_DDC_DATA)
                  PCH was really supplied with 19V
                  • hansie55
                    • Dec 2013
                    • 254
                    • Netherlands
                    #29
                    "pin 26,27 = 1,07V
                    pin 28,29 = 0V
                    pin 30,31 = 1,05V
                    pin 32 = 0V"
                    Values are the same, except pin 30, it went to 0V
                    • hansie55
                      • Dec 2013
                      • 254
                      • Netherlands
                      #30
                      You are the Pro, so I assume you right.
                      I still do not understamd how pin 25 got to pin 6, that's a loop in the screen logic?
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        #31
                        Normally you got 19v on pin 25 to supply screen led . But at the time you reversed lvds cable the 19v went on pin 6 with is directly connected to pch lvds pin
                        • hansie55
                          • Dec 2013
                          • 254
                          • Netherlands
                          #32
                          I understand, but my way of thinking was different. The supplied voltage is on connector CN3000 pin 25, and if you stick in the lvds cable reversed, the supply of 19V is given to pin 6 of the cable, which will kill the lcd logic, but I don't see it return from there to PCH.
                          The cable connector was put in reversed, not the CN3000
                          • dycc
                            Vision
                            • Nov 2011
                            • 625
                            • Côte d'Ivoire
                            #33
                            i understand, but my way of thinking was different. The supplied voltage is on connector cn3000 pin 25, and if you stick in the lvds cable reversed, the supply of 19v is given to pin 6 of the cable, which will kill the lcd logic, but i don't see it return from there to pch.
                            The cable connector was put in reversed, not the cn3000
                            you are right . But short in the lcd logic will return back to pch .
                            • hansie55
                              • Dec 2013
                              • 254
                              • Netherlands
                              #34
                              Understood, thanks for your patience
                              • hansie55
                                • Dec 2013
                                • 254
                                • Netherlands
                                #35
                                Hey Guys,
                                Since it looks like the PCH is dead I stopped repairing this laptop. I do not have the equipment to replace the PCH and the investment to have it done is not worth it.
                                I thank everybody who participated in this thread for their time and effort.
                                Thanks Guys, Later..
                                  09-06-2024, 05:27 AM
                                  09-06-2024, 05:59 AM
                                  Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                  This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                  09-06-2024, 05:33 AM
