MAcbook Air A1466 EMC 3178 - 2017 Boot
  • Sergio Kub
    • Jul 2018
    • 179
    • Brasil
    Could someone help me?
    I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
    Could it be the BIOS?
  • mon2
    • Dec 2019
    • 14838
    I would try to clean the contacts of the removable SSD with IPA (alcohol) and then test again.
    • Sergio Kub
      • Jul 2018
      • 179
      • Brasil
      mon2
      I've already cleaned it with IPA and heated each contact terminal in the SSD slot, and I've also replaced the NVME SSD. Every now and then, the paste and the question mark appear. Strange, I've never had a problem like that. Thanks.
      • Sergio Kub
        • Jul 2018
        • 179
        • Brasil
        I removed the board and noticed that it had solder flux marks on the top.
        They had already handled it and hadn't been careful.
        I returned it. Thank you!
        • Sergio Kub
          Macbook Air A1466 EMC 3178 - 2017 Boot
          by Sergio Kub
          07-08-2025, 04:12 PM
        • jheunne
          A1466 macbook no boot green to orange light help
          by jheunne
          i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
          in first image there is 0v out for lcd
          https://ibb.co/5XppmpkH
          in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
          https://ibb.co/fdJkbJs8
          06-10-2025, 10:52 PM
        • BMCappelletti
          Macbook Air A1466 EMC 3178 missing power and liquid damaged
          by BMCappelletti
          Hi everyone.
          Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
          Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
          04-15-2024, 01:24 PM
        • sherifu
          Macbook Air A1466 Emc 3178 No light charger after spilling liquid
          by sherifu
          Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
          03-26-2024, 04:54 PM
        • longislandtea
          MacBook Air 2017 A1466 EMC 3178 820-00165-A No power
          by longislandtea
          Hi, I' ve this MacBook Air with a strange problem. This laptop come in to my shop with initial problem PULSING (ON/OFF, no fan)
          I wrote this attached bios dump that I clean me region by ME INJECT software and Macbook Power on but have a strange defect.
          The Macbook Power on only when I connect the AC adapter without battery. It Never power on by clicking power key on keyboard. I also tryed to power on by SMCbypass on the motherboard.
          When Macbook is ON and I press ON/OFF key the macbook go off without problem
          I tryed to clean me region...
          02-14-2021, 10:11 AM
