HP 15-da0073wm display issue
  • Norag33
    • Mar 2024
    • 20
    • Cuba
    Hey guys i need your help to fix this problem with this HP 15-da0073wm i7-8550U, this laptop originally has a 40 pin display connector for the Cell Touch eDP display and since i couldn’t acquire that display i decided to adapt the 40 pin connector to 30 pins discarding the touch related pins since the first 30 pins are the same as non-touch eDP displays, the problem is that it worked but not as i expected, you can see the problem in the pictures, i already tried to isolate the display cable from external interference or i think so, i tried with other displays but no video just black screen, i also tried that display on another laptop and it worked normally, please help me i don’t know what to do now
  • mon2
    • Dec 2019
    • 14677
    Resolution and scan rates the same between the 2 display models?
    • m1ch43lzm
      • Mar 2019
      • 948
      • Peru
      What about replacing the LCD cable with the proper one for the non touchscreen model?
      Like this one: https://es.aliexpress.com/i/1005004116295048.html
      Search for "HP 15-da LCD cable"
      According to the AliExpress listing is the same cable for:
      • 15-DA
      • 15-DB
      • 250 G7
      • 255 G7
      Trying to adapt those cables is difficult considering eDP is a high speed signal and you have to carefully match the length of each differential pair, and no splices allowed in the middle of the cable
      • Norag33
        • Mar 2024
        • 20
        • Cuba
        • 15-DA
        • 15-DB
        • 250 G7
        • 255 G7
        I tried with a 15-db cable I had laying around but the issue remains
        • Norag33
          • Mar 2024
          • 20
          • Cuba
          I do not have the original display I got the laptop without it
          • m1ch43lzm
            • Mar 2019
            • 948
            • Peru
            According to HP partsurfer, these are the compatible part numbers
            The non touch screen, as a reference I used 15-da0010la
            Part Number : L20379-001
            Part Description :
            LCD RAW PANEL 15.6 HD BV
            From one seller description: L20379-001 B156XTN07.0
            Part Number : L20443-001
            Part Description :
            EDP CABLE NTS​
            Touch screen, yours 15-da0073wm
            Part Number : L20380-001
            Part Description :
            LCD RAW PANEL 15.6 HD BV TOP​
            From a seller description: B156XTK01.0,B156XTK01.0 HW3A, N156bgn-e41, N156bgn-e41 REV C.1
            Part Number : L20442-001
            Part Description :
            EDP CABLE TS​
            Both are HD 1366x768 resolution
            Schematics: https://www.badcaps.net/forum/troubl...78067-la-g07ep
