Acer Predator Helios 300 - will not power up if battery is CONNECTED
  • mon2
    • Dec 2019
    • 14274
    This is normal behaviour of the battery mosfet.
    Connect the battery and power adapter. Measure the voltage to ground on each pin of the battery connector. We are testing the SMBUS interface voltages.
    • survivalbloke
      • Aug 2021
      • 302
      Man, I can't wait to have as much experience as you. battery and charger connected, 12v on the battery terminals.
      • mon2
        • Dec 2019
        • 14274
        I think there is more ROI in opening an only fans website.
        Does your battery offer more connections or only the power (+) and ground? There should be more contacts on the battery pack. 2 of them = i2c / smbus = SCL / SDA lines. We need to measure these as well.
        Post a pic of your battery connector.
        • survivalbloke
          • Aug 2021
          • 302
          As requested!
ID:	3690460 Click image for larger version
          • mon2
            • Dec 2019
            • 14274
            So the 3 x RED - hot; black = ground.
            We are also interested in the voltage to ground of the other rainbow colored wires in the middle area. 2 of them are for sure the SMBUS / I2C lines of interest. Mate this connector to the board and measure their voltage to ground for each.
            • survivalbloke
              • Aug 2021
              • 302
              It's actually 2x red. Then an orange, but that one looks red in the picture.
              Orange=.05v
              Yellow=.15v
              Green & Blue=3.3v
              • mon2
                • Dec 2019
                • 14274
                Go back to PQB4 as suggested by SMDFlea.
                Remove all power. Meter in resistance mode.
                Measure the resistance across this mosfet:
                source (1-2-3) & drain (5-6-7-8)
                source (1-2-3) & gate (4)
                gate (4) & drain (5-6-7-8)
                Post each measurement. The mosfet can be defective yet pass through the voltage onto the rail through the internal diode.
                When you attach both the power adapter & battery - what is the voltage to ground of the gate pins on PQB3 & PQB4. For this case, you should have ~25v on the gate pins.
                • survivalbloke
                  • Aug 2021
                  • 302
                  source (1-2-3) & drain (5-6-7-8) = 1.4M
                  source (1-2-3) & gate (4) = 2.5M
                  gate (4) & drain (5-6-7-8) = 2.5M
                  25v to ground on gate of PQB3 and PQB4
                  • mon2
                    • Dec 2019
                    • 14274
                    Looks ok to me.
                    Disconnect the battery. Measure the voltage charge on the battery - black probe to black wires; red probe onto the red wire. What is the voltage?
                    1) Measure the resistance to ground on either side of PLB2. We are checking if the low side mosfet is leaking.
                    2) As before, measure the resistance across the high side mosfet @ PQB5. Someone on this board has a conflict when both the power adapter & the battery are mated so need to study each suspect.
                    Post the usual:
                    source / drain
                    source / gate
                    gate / drain
                    resistance values for PQB5. If PLB2 to ground is with a low resistance then PQB6 is a suspect since it is connecting to ground.
                    Both, PQB5 & PQB6 work together to drill down the Vin from the adapter to create a suitable charge voltage for the battery pack. Assuming the battery pack is not defective, it should charge with a slightly higher voltage than what is printed on the casing of the pack. Respectively, when you power up with the adapter & battery pack, what is the voltage on PLB2 to ground? This is the same charge voltage for the battery pack.
                    • survivalbloke
                      • Aug 2021
                      • 302
                      Looks ok to me.
                      Post the usual:
                      source / drain
                      source / gate
                      gate / drain
                      Battery pack voltage is 15.49v
                      PLB2 to ground is 10M with red probe on ground, but 25M with black probe to ground. I didn't think meters measured resistance mode with polarity.
                      PQB5: S/D = 11M, S/G = 104k, G/D = 5.9M
                      Voltage on PLB2 with power adapter and battery pack connected is 15.49v, the exact voltage of the battery back when disconnected.
                      • mon2
                        • Dec 2019
                        • 14274
                        S/G is too low. Flux and remove this mosfet. Allow the mosfet to cool. Test the S/G resistance on the mosfet. Is it still this low? A good mosfet should be hundreds of k ohms or higher. The current resistance indicates the mosfet is defective.
                        • survivalbloke
                          • Aug 2021
                          • 302
                          Mosfet removed, S/G and D/G are both now OL.
                          • mon2
                            • Dec 2019
                            • 14274
                            Are these measurements on the removed mosfet while the part is on your workbench or the measurements of the PCB pads without this mosfet?
                            • survivalbloke
                              • Aug 2021
                              • 302
                              mosfet removed and on workbench.
                              • mon2
                                • Dec 2019
                                • 14274
                                The mosfet is ok. Leave it off the board. This is the high side mosfet. Attach the battery and power up again. The battery will not charge because this high side mosfet is missing.
                                Does the board power up?
                                Is the battery detected by the os? Is the adapter detected by logic board? Check the bios.
                                • survivalbloke
                                  • Aug 2021
                                  • 302
                                  wait, that was the wrong battery.
                                  • survivalbloke
                                    • Aug 2021
                                    • 302
                                    OK, confirmed, with that mosfet removed and the battery installed, the laptop powers up and the OS recognizes a battery is installed, and as you mentioned, it does not charge. I then verified, reinstalled that mosfet, and again, the laptop will only power up if the battery is disconnected.
                                    • mon2
                                      • Dec 2019
                                      • 14274
                                      Is your meter auto ranging for resistance?
                                      Remove all power and measure the resistance of the same mosfet that was soldered back.
                                      source & drain
                                      source & gate
                                      gate & drain
                                      post each measurement.
                                      • survivalbloke
                                        • Aug 2021
                                        • 302
                                        source & drain = 2.5M
                                        source & gate = 200k
                                        gate & drain
                                        = 2.2M
                                        gate & drain
                                        = 2.2M
                                        Yes, my meter is auto ranging.
                                        • mon2
                                          • Dec 2019
                                          • 14274
                                          is too low. This could be again due to in-circuit testing but recommend to test with a fresh mosfet here.
