acer aspire s3 cant turn on
    when pluged in charger it shows charging with red led .standby current is ok .i tried with battery and without battery cant turn on.power switch also working and the voltages around it also ok..................any ideas
    Re: acer aspire s3 cant turn on
    when i tried with battery it shows 5 blinks on charging led
      on aspire one 5 blinks its the power brick !
      it indicates that you need a proper power supply!
      get in to that check the dc jack adapter bla bla bla.
      tell us after what happen
        dc jeck is ok 19v, 3valws 5v alws all are ok
          i want to know that how much voltage i should have on power switch
            anybody deal with that type of issue before
              try to flash EC Bios..!!
                already tried but i used the downloaded`file from acer wibsite. any body have orignal file for this model acer aspire s3-951 please shere it for me
                  3volts goes to ground when pressed
                    Yes
                      What is the voltage at the battery terminal with out the battery
                        3v
                          Is this the diagram I am looking at
                            after changing kbc still same.i am getting 1v instead of 3v on power switch
                              did ask 4 post back the voltage at the switch 1v too low take out the ribbon cable and check the voltage at the gap G2701 point and use that to power it for test if voltage is 3 volts
                              page 27 bottom right corner
                                I`m wondering if the bios battery its not low 3v maybe it should be 3.3v because the first stage in acer its +RTC_VCC
                                check in to that and see if you swap the bios battery what happens.
                                  after changing rtc battery still same
                                    any body have solution
                                      did any body have bios for this model
                                        Try this, use WinRAR to open it.
