MacBook Pro 15" A1707 820-00281 turns on once in 10 (or maybe more)
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    I have this macbook that is behaving abnormally. Initially it had a battery life problem, after changing the battery everything seemed ok, but after about 5 days it started giving problems. It turns on once in 10 (or maybe more), more often after I unplug the battery connector and plug it back in. Sometimes after SMC reset. But it's not a stable rule. Visual inspection shows no problems, no signs of liquid contact or burning. Looking with the thermal camera I notice that the chip that heats up the most is U7220.
    Any suggestions?​
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    I should add that using a tester on the micro USB connector I note that the input voltage detected is 5V
    • mon2
      • Dec 2019
      • 14209
      Are you using the official and recommended power adapter for this model? Suggest to use a 100W rated usb-c power adapter with a certified 100W power cable to the board.
      This detail is important to allow for the peak power delivery contract of 20v 5A to be selected.
      • mon2
        • Dec 2019
        • 14209
        If your PD contract is at the power up default of 5V, then inspect the details of each and every PD controller (CD3215).
        Review this article:
        https://logi.wiki/index.php/CD3215_Bootup_Sequence
        Also suggest to remove all power. Meter in resistance mode. Measure the resistance to ground on each and every inductor on the board. Each inductor is linked to a local power supply rail and you may have a borderline shorted capacitor on the rail which is causing an excessive current draw. This is being sensed by the power supply and shuts down the power up sequence.
        Be sure the contacts of your USB-C connectors are clean and without debris / cat urine, etc. Use IPA alcohol to clean up the contacts on the USB-C paddle board used by the logic board. Often, this action alone can fix up such cases.
        • ryogadan78
          • Nov 2021
          • 66
          • Italia
          Hi mon2, thanks as usual for your support. You are right, with original power adapter I read 20V on USBC port, but the main problem remain the same (doesn’t turn on).
          • mon2
            • Dec 2019
            • 14209
            The USB-C meter in the posted pic is being used in the reverse direction. Please note the direction arrow which shows the flow of the current. This installation may be result in inaccurate measurements.
            Can you seat the meter so that the INPUT side is facing the power adapter? You may have to seat the INPUT plug directly to your power adapter and then use the 100W rated power cable to your laptop.
            • ryogadan78
              • Nov 2021
              • 66
              • Italia
              Hi mon2, thanks for the suggestion. I too had noticed the input and output indications, but strangely I never saw any difference in reading the data. I attach photos taken today
              • mon2
                • Dec 2019
                • 14209
                Be sure that the white USB-C cable is rated for 100W. This is important. Only high power cables will feature an e-marker IC inside the hoods to allow for higher power delivery contracts to be negotiated from the power adapter.
                For this model, from the Rossmann forums:
                Make sure you are using a 87w charger (or higher) and USB-C cable that is rated for 5 amps.
                • Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                  by Stephen
                  MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                  03-15-2024, 09:37 AM
                • tommy97
                  Apple MacBook A1707 No Audio/Sound
                  by tommy97
                  I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                  I've also replaced U6300, but the problem persists.
                  Here are the current voltage readings:
                  • PPV18_S0: 1.8V
                  • R6402: 1V
                  • R6405: 1V
                  • R6403: 1V
                  • AUD_SPKRAMP_RESET_L: 1.3V
                  • PPBUS: 12.6V
                  03-10-2025, 11:22 AM
                • Cemal Odabasioglu
                  MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                  by Cemal Odabasioglu
                  I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                  Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                  Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                  Observations...
                  01-14-2025, 03:54 PM
                • Herby94
                  MacBook Pro A1707 Won’t Boot – No Display, Fans Spin Briefly
                  by Herby94
                  I’m currently having an issue with my MacBook Pro (A1707). It doesn’t power on or make any sounds.
                  • The charger is a generic third-party unit that had a loose connection at the AC input (127VAC). I fixed it, and now it delivers 20VDC to the laptop.
                  • When connected, the fans spin for about 30 seconds before shutting off.
                  • No display, no audio, and no signs of life during this time.
                  Any ideas? Could this be a logic board issue, or is the charger still a problem? Thanks in advance!...
                  Today, 08:59 AM
                • Stephen
                  A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                  by Stephen
                  Hello, got a weird MacBook Air here
                  board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                  08-23-2023, 09:12 AM
