Lenovo T14 MainBoard NM-C931 no image
  • dggn
    • Aug 2016
    • 6
    • Poland
    Laptop as in the subject. No image and no voltage on the PL1002 coil. According to the schematic it is the value of VCCGFXCORE_I. CMOS battery removed. Maybe someone had a similar problem and direct what to check ?
    Current consumption 722mA board on, 22mA board off. And below the voltage and resistance values of all coils
    PL0401 5.31V
    PL0201 9.30V
    PL0501 3.3V
    PL301 5.1V
    PL1201 1.2V
    PL1301 1V
    PL1002 0V
    PL0902 0.8V
    PL0904 0.8V
    PL0903 9.2V
    PL0909 0.8V
    PL1102 1V
    PL1502 0.8V
    PL1501 0.8V
    PL1601 1.3V
    L5602 0.9V
    PL0401 86kΩ
    PL0201 0,6MΩ
    PL0501 5,2kΩ
    PL301 114kΩ
    PL1201 151kΩ
    PL1301 54Ω
    PL1002 6,7Ω
    PL0902 4,3Ω
    PL0904 4,1Ω
    PL0903 16MΩ
    PL0909 5,3Ω
    PL1102 16,9Ω
    PL1502 5,6Ω
    PL1501 4,8Ω
    PL1601 604Ω
    L5602 0,95kΩ​
    • 21597
    Link to schematic & boardview -> https://www.badcaps.net/forum/troubl...31#post1768898
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Try disabling onboard ram
      • dggn
        • Aug 2016
        • 6
        • Poland
        I tried to disable using this thread
        https://www.badcaps.net/forum/troubl...1-thinkpad-t14
        And also edited the bios using this thread
        https://www.badcaps.net/forum/troubl...-scripts/page2
        but nothing helped
        • Sephir0th
          • Oct 2020
          • 1283
          CapsLock test?
          FairRepair on YouTube
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            There is no proven bios claiming to disable onboard ram for this model in this forum and ram disable thru that script posted by smdflea dont work in majority of the cases.
            So i'm not confident whether ram is disabled correctly or not. Unfortunately, i dont have any solution either for this model.
            • n_pac
              • Feb 2023
              • 8
              • Albania
              Originally posted by Sephir0th
              CapsLock test?
              I was looking at your video for about this kind of Lenovo T14 gen 1 and that PD controller video is very helpful. Thank you mate! I also have a USB Type C power jack problem, one of the VBUS pins is detached from the board and the questions are:
              1- Since there are 4 VBUS pins connected together, would be any problem if one of the VBUS is missing?
              2- The resistor R6304 it is not giving any ohm value and I think the current it's not flowing through it! Probably damaged from any short circuit..! Could this be the problem that I am not having 20V in the test point TP6301 or at USBC_VBUS20 test point? (part of schematic image attached)
Name:	Annotation 2025-05-29 220903.png
              3- What is the CapsLock test and how to perform it?
              Thank you in advance
              Danke schon!
              • Sephir0th
                • Oct 2020
                • 1283
                If one single pin is missing, it most likely isn't a issue for a board which doesn't consume a lot of current. R3604 is supposed to measure 1 MegaOhms. If the multimeter isn't auto-ranging, it has to be set manually to the 200K or 2M range to measure properly.
                however, there should be at least 5 Volts to measure at USBC_VBUS20_CONN, otherwise you are dealing with another problem here. Like a short to GND on this track, or maybe the other three pins not attached to the board too anymore? What's the history here?
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
                  HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                  09-06-2024, 10:56 AM
                  HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
