Dell XPS 13 9370 - CAZ60 LA-E671P No POWER, No CHARGE
  • D@nt3s_1nfern0
    • Mar 2025
    • 26
    • Greece
    Hi there guys i have this laptop that doesnt power on. When i plug the charger i see 2 white blinks on the front leds with a small delay. If i press the power button the led ligts up for less than a second then dies down.
    When i plug in the USB AMP meter on the Type C i get 20v and a jump up to 0.34A then the value changes to 5.02v 0.03-5A. Please if someone could guide me on how to troubleshoot and possibly fix it. i am new into fixing boards so this will be a valuable lesson to me.
    Thank you in advance guys .
  • mon2
    • Dec 2019
    • 14230
    Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor (often grey in body color and with 2 pins - one on each side). Each such inductor is linked to a local switching power supply. Each rail is being tested for shorted parts which will cause that local power regulator to sense an excessive current draw and then that power rail will power off for safety.
    Post any suspects found during your inspection.
    What is the history of this unit? Just died one day? A good day to die?
    • D@nt3s_1nfern0
      • Mar 2025
      • 26
      • Greece
      Hello and thank you for your reply.
      Just stoped working one day. i dont see any obvious issue on the board like burn or liquid damage.
      ok so here are the inductor measurements
      PL1100 =7.1 ohm
      PL1103 = 7.1 ohm
      PL1150 = 10.5 ohm
      PL301 = 28 Kilohm
      PL302 = 128 Kilohm
      PL501 = 28.1 Kilohm
      PL504 = 50 Kilohm
      • D@nt3s_1nfern0
        • Mar 2025
        • 26
        • Greece
        The first 3 that their measurements are on the range of ohms does that indicate a short ?
        • mon2
          • Dec 2019
          • 14230
          PL1100 =7.1 ohm
          PL1103 = 7.1 ohm
          PL1150 = 10.5 ohm
          Each is ok. The first 2 are linked to VCORE = CPU power rail. By design low voltage rails are with a low resistance to ground.
          PL1150 = power rail for the GPU. Again, not considered a short.
          Review the charger IC @ PU300.
          Carefully measure only if you have fine tipped meter probes, the voltage to ground of the following:
          Pin 17 ; DCIN for PU300
          Pin 19 ; CHG_ACIN
          Pin 24 ; ACOK
          Pin 15 ; CSIP
          Pin 14 ; CSIN
          Post each measurement.
          • D@nt3s_1nfern0
            • Mar 2025
            • 26
            • Greece
            Pin 19 ; CHG_ACIN
            Pin 24 ; ACOK
            Pin 15 ; CSIP
            Pin 14 ; CSIN
            Pin 17 = 8.5v
            Pin 19 = 0.912v
            Pin 24 = 3.045v
            Pin 15 = 4.999v
            Pin 14 = 4.999v
            • mon2
              • Dec 2019
              • 14230
              PD300 appears to be defective. You should see the power adapter voltage on pin #17. Confirm again. The higher of the 2 power sources should appear on pin #17.
              • D@nt3s_1nfern0
                • Mar 2025
                • 26
                • Greece
                ok so when i plug in the usb meter with the power adapter the meter shows 20v and in the pin 17 shows 20v as well but after a few seconds the usb meter drops to 5v and then the measurement on pin 17 drops to 8.5v
                • mon2
                  • Dec 2019
                  • 14230
                  Noted. Remove all power. Meter in resistance mode. Measure the resistance between pins #1 and #2 on PU300. Confirm the full path resistance for the battery charger circuit. This total resistance must be close to the schematic values else the charger IC will see this is as a risk and power down. Post the measurement.
                  Measure directly on the charger IC pins (without power).
                  • D@nt3s_1nfern0
                    • Mar 2025
                    • 26
                    • Greece
                    Ok just to confirm that i will put the one probe on pin 1 and the other on pin 2 no matter the colors right ? if thats the case then i do get 4.3 ohms
                    • mon2
                      • Dec 2019
                      • 14230
                      Correct. The resistance is correct and is not the fault.
                      Is the USB-C power adapter the original device for this laptop? You cannot use a cell phone / mobile charger.
                      • D@nt3s_1nfern0
                        • Mar 2025
                        • 26
                        • Greece
                        It is the correct carger indeed. model No: HA45NM180
                        • mon2
                          • Dec 2019
                          • 14230
                          What are the results if you power up without the battery connected? Is the 20v steady or also powers up / down to 5v?
                          • D@nt3s_1nfern0
                            • Mar 2025
                            • 26
                            • Greece
                            It powers down to 5v after a while. checked all the 3 ports
                            • mon2
                              • Dec 2019
                              • 14230
                              Does it reach 20v without the battery?
                              Measure the voltage to ground on each pin of the battery connector. The SMBUS (SCL / SDA) pins are of most interest. These lines are also used to communicate with the charger IC. If either of the TVS diodes have triggered, they will shunt the communication.
                              • D@nt3s_1nfern0
                                • Mar 2025
                                • 26
                                • Greece
                                yes it does
                                • D@nt3s_1nfern0
                                  • Mar 2025
                                  • 26
                                  • Greece
                                  should i do that with the battery connected ?
                                  • D@nt3s_1nfern0
                                    • Mar 2025
                                    • 26
                                    • Greece
                                    Pin 6 = 3.094v
                                    Pin 7 = 3.374v
                                    Pin 8 = 3.374v
                                    Pin 9 - 12 = 5.023v
                                    • D@nt3s_1nfern0
                                      • Mar 2025
                                      • 26
                                      • Greece
                                      took the readings with the battery disconnected. If i had to do it with the battery being connected please let me know
                                      • mon2
                                        • Dec 2019
                                        • 14230
                                        What is the voltage to ground of:
                                        Pin 16 ; ADP (PU300)
                                        ALW_PWRGD_3V_5V
                                          DELL XPS 9370 Notebook 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9370 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9370 boardview and 9370 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9370 Notebook...
                                          09-06-2024, 08:01 AM
                                          09-06-2024, 07:11 AM
