Dell XPS 13 9370 - CAZ60 LA-E671P No POWER, No CHARGE
  • D@nt3s_1nfern0
    • Mar 2025
    • 26
    • Greece
    Originally posted by mon2
    What is the voltage to ground of:
    Pin 16 ; ADP (PU300)
    ALW_PWRGD_3V_5V
    PU300 Pin 16 voltage is 4.999v
    the net name you mentioned underneath corresponds to PU500 , if thats the one you wanted then the voltage on Pin 16 was 3.374v
    • mon2
      • 14713
      Measure the voltage on pin #9 of PU500 = PG = power good. Must be a logic '1' to denote the power is good.
      • D@nt3s_1nfern0
        • Mar 2025
        • 26
        • Greece
        voltage on pin9 of PU500 is 3.344v
        • mon2
          • 14713
          Some of the inductor checks from post #2 were missed. Measure the resistance to ground of:
          PL601
          PL701
          PL801
          PL901
          PL1107
          PL1151
          PL1403
          PL1401
          PL1503
          PL1501
          • D@nt3s_1nfern0
            • Mar 2025
            • 26
            • Greece
            PL601
            PL701
            PL801
            PL901
            PL1107
            PL1151
            PL1403
            PL1401
            PL1503
            PL1501
            PL601= 600 ohm
            PL701= 105 ohm
            PL801= 1.2 mega ohm
            PL901= 1.2 mega ohm
            PL1107= there is no component there
            PL1151=23.4 Ohm
            PL1403= 72 OHM
            PL1401=98 OHM
            PL1503= there is no component there
            PL1501= there is no component there
            • D@nt3s_1nfern0
              • Mar 2025
              • 26
              • Greece
              #26
              PL601
              PL701
              PL801
              PL901
              PL1107
              PL1151
              PL1403
              PL1401
              PL1503
              PL1501
              in the places that are no components sould i just measure the pads ?
              • mon2
                • 14713
                No components should be ok to leave alone. They are likely optional parts for optional versions of the PCBA builds. Assuming that this unit worked as-is before otherwise if purchased from Ebay or similar - perhaps someone removed parts before selling the unit to you? Have had this happen on Ebay to us. Vultures in California - some hack of a repair shop there stripped off many critical parts from a macbook before selling to us. Destroyed our USB-C charger upon first use.
                • D@nt3s_1nfern0
                  • Mar 2025
                  • 26
                  • Greece
                  #28
                  No the device was not purcased from ebay. also i can confirm that the solder joints they look factory. so i believe they are optional for other versions of PCBA.
                  Is your mind guessing why te board is behaving like that? you think the PU300 is faulty ?
                  • mon2
                    • 14713
                    No. Suspecting at this time that there is something wrong with the power delivery controller. The PD controllers @ U19 / U20 / U21 are responsible to communicate with the external power adapter to extract the power contracts and then select the best one to fully power this board. Perhaps the firmware of the PD controller (held inside of UT6) is corrupted. It is strange that the 20V pd contract is actually selected and then reset back to the 5v default.
                    Do you see the same reaction for all USB-C ports? Do test each USB-C port by rotating the USB-C connector by 180 degrees to confirm the opposite side of each connector. This process will test the CC1 and also the CC2 communication lines that are present on each USB-C connector.
                    • D@nt3s_1nfern0
                      • Mar 2025
                      • 26
                      • Greece
                      #30
                      Yes i just did checked all 3 usb ports on both sides of the Type C. They all behave the same. Is there a controller that regulates all of these ports ?
                      • mon2
                        • 14713
                        There is a local PD controller for each port but it appears that only one is holding the firmware @ UT6 flash device. One thought is that perhaps after the 20V PD contract is reached, an event of excessive current draw occurs and is reported back to the PD controller(s) to power down. This flag would be through one of the GPIO pins on the PD controllers and the firmware would have to be coded to support this feature.
                        Suggest to backup and reflash UT6 provided a dump of this flash memory is available. Only a suggestion to rule out firmware corruption. It does take working firmware to negotiate the 20v contracts but why does it reset back to 5v??
                        Are you power cycling with the USB-C meter?
                        • D@nt3s_1nfern0
                          • Mar 2025
                          • 26
                          • Greece
                          #32
                          Hello mon2 and goodmorning (from greece)
                          unfortunately i do not have the tools to do reflash of the UT6. Can that chip be replaced if i buy one from the internet ?
                          i tried to power cycle with and without the usb-c meter
                            DELL XPS 9370 Notebook 13 Specification for Upgrade or Repair
                            This specification for the DELL XPS 9370 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9370 boardview and 9370 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9370 Notebook...
                            09-06-2024, 08:01 AM
                            09-06-2024, 07:11 AM
