Dell Latitude 5320 USB-C port issue
  • D3D_Tray
    • Oct 2024
    • 11
    • BDR GmbH
    Hey guys,
    so my half-year out of warranty Dell Latitiude 5320 (19817-1 SOUTH PEAK 13 10L) w/ i5-1145G7 and 16GB just started to act weirdly...
    The first/upper USB-C/TB port suddenly didn't accepted the charger every time and sometimes only a different one... or with a different cable but so far, the self-diagnostics didn't noticed anything so I suspected a dirty port.
    Today however... it stopped completely to accept a charger, the second/bottom one however does and after a half an hour, I notice something getting hot under there... blazing hot!
    I traced the issue down w/ alcohol (too poor for thermal camera) and it's a 5pin IC with the marking "53B7" (see picture)
    Diode readings to GND from top to bottom;
    1L = 14Ohm
    2L = 0Ohm
    3L = 1310Ohm
    1R = 14Ohm
    2R = 1840Ohm
    Now I'm asking you for help... may that be the real issue or is something more beyond that?
    Best regards
    ~Daniel
  • mon2
    • Dec 2019
    • 14370
    Suspecting this to be a SOT23-5 packaged TVS ESD diode array. Flux and carefully remove the part and test the PCB pads again (without his part on the board).
    Also, when you are in DIODE mode, these are voltage readings.
    When you in RESISTANCE mode, they will be in ohms.
    When in DIODE mode, be sure the RED meter probe is to ground. Black meter probe on the pin to test.
    • hobostove
      • May 2023
      • 73
      Looks like a switch/mosfet. It may have gone short. Remove it like mon said, and test resistance between each of IN, OUT, and GND pins. Should be 6 readings. Also test the board pads resistance of IN and OUT to GND. Let us know what you find.
      Click image for larger version  Name:	image.png Views:	0 Size:	42.4 KB ID:	3622350
      Click image for larger version  Name:	image.png Views:	0 Size:	4.1 KB ID:	3622351
      Chip Datasheet: https://cdn.badcaps-static.com/pdfs/...41e690a0ad.pdf
      • D3D_Tray
        • Oct 2024
        • 11
        • BDR GmbH
        Ahhh okay, TY
        1L = 500 kOhm initial, raising to infinit kOhm but slowly
        2L = 1, 1 Ohm
        3L = 55,9 kOhm
        1R = 2,4 kOhm initial, raising up to 4,3 kOhm
        2R = 104 kOhm
        • mon2
          • Dec 2019
          • 14370
          TY for the correction.
          Pin # 1 is much healthier now after this part was removed. This USB load switch is defective. Needs to be replaced. Study the pinout and compare to other drop in parts from Texas Instruments / Diodes Inc. / Microchip, etc. There are many similar vendors that can drop into this same space. This is a current limited load switch and they just die after a transient. Wimpy by design. You can define the peak current support by the part you will purchase.
          Before ordering, share the full details on what you intend to purchase.
          • D3D_Tray
            • Oct 2024
            • 11
            • BDR GmbH
            Uhm, now I'm bit confused but on the chip itself, I got these readings;
            IN - OUT = 2 Ohm
            IN - GND = 14,5 Ohm
            OUT - GND = 14,5 Ohm
            (used the G524 images as pinout)
            On board I got;
            IN - OUT = 16 kOhm initial, raising to infinite kOhm slowly
            IN - GND = 2 kOhm initial, raising to 4,6 kOhm
            OUT - GND = 500 kOhm initial, raising to infinite kOhm slowly
            • hobostove
              • May 2023
              • 73
              Yeah, switch is definitely dead. The 5V in has only 14.5 ohms to jump to ground. No wonder is was getting so hot. Almost 2 watts going through that tiny chip!
              Thermal Resistance Junction to Case, (θJC)
              SOT-23-5. . .60°C/W (Means it was about 120C above room temperature) 😅
              Board is good. Time to order a chip
              • mon2
                • Dec 2019
                • 14370
                TBH the original part vendor is crap. Most of these switches do die under such transients but my money would be on a TI or Diodes Inc. or Microchip part before a China only vendor.
                • D3D_Tray
                  • Oct 2024
                  • 11
                  • BDR GmbH
                  I'm honest with you... I have right now no idea what I am looking at, the datasheet says something about 5V power limiter but... I had issues with charging the notebook at 20V (or whatever PD negotiated) and ...
                  *brain melting* So I need a replacement USB load switch for 5V and 2.5A (that probably is meant to prevent over-current over 5V for all ports
                  https://www.mouser.de/c/semiconducto...=Load%20Switch
                  • hobostove
                    • May 2023
                    • 73
                    It's possible it's just a coincidence. One way to find out is you can power it up with that chip taken out. You just won't have 5V on that USB-A port, so it won't work. But everything else will work fine
                    • D3D_Tray
                      • Oct 2024
                      • 11
                      • BDR GmbH
                      Hmm... Both USB-C/TB ports takes power and PD in except the first/upper port only on one side, I tried with several cable different cable and my Lenovo USB-C brick (don't have the Dell original one)
                      Maybe USB-C port is a bit loose? Loose and somehow bricked the IC by accident? (At least no heater inside anymore)
                      I use a J7-c in between to check the voltages and something caught my eyes, I have one cable with a small display for Watt reading and if PD is enabled or not, no matter how I flip it, it keeps blinking on the first/upper port but not on the second/bottom port (on the picture I've sent it's upside down ofc ^^)
                      • hobostove
                        • May 2023
                        • 73
                        The switch chip may have been broken for a while, and you just noticed it because you were actively looking for a problem. Don't think it's related to the USB-C issue.
                        The fact that it got worse overtime and didn't just suddenly stop makes me think the port is dirty or damaged. Try to get a good look at the pins. You'll need a magnifying glass or microscope, etc.
                        What does the J7-C tester say on that port? Does its screen come on?
                        • D3D_Tray
                          • Oct 2024
                          • 11
                          • BDR GmbH
                          The J7-C test only powers up on one side, the other side it acts like being not connected.
                          Are there any testpoint on the board to test the USB-C pins? I have a breakout board for USB-C so I could check for continuity on each pin (the manual way)
                          I also realized this morning that only the USB-A port on the same side doesn't have 5V, the other side still functions fine :o
                          • hobostove
                            • May 2023
                            • 73
                            On the side it powers up on, does it negotiate more than 5V?
                            Not turning on at all means an issue with the CC lines. Since it works one way but not the other I'd say the port itself being bad is very likely.
                            • D3D_Tray
                              • Oct 2024
                              • 11
                              • BDR GmbH
                              Nothing, no 5V or PD negotiation, I even externaly powered the JC-7 but it's dead. Even when I try to attach as USB-C device, only works on one side (tested just now) so I assume...
                              A worn out USB-C port (nice... yesterday first time desoldering a tiny IC with hot air and now an USB-C port although I have low-melt solder w/ bismuth)
                              • D3D_Tray
                                • Oct 2024
                                • 11
                                • BDR GmbH
                                I found the SY6288D20AAC which looks good... I think...
                                https://www.silergy.com/productsview/SY20808C20AAC
                                • mon2
                                  • Dec 2019
                                  • 14370
                                  Indeed. Looks like a good fit to me. Same pinout, active LOW enable signal which is important. Most are active HIGH enable signals, so this is a good find.
                                  • hobostove
                                    • May 2023
                                    • 73
                                    Soldering them can be a bit of a pain since there's usually a row of pins hidden under the port, you can't reach them with an iron or make sure they're connected. But you have hot air, and that's all you need.
                                    I found this option for buying it quickly. There's also Aliexpress for cheaper, but it'll take longer.
                                    https://www.amazon.de/-/en/Latitude-...dp/B0DBVD939T/
                                    Here's what the repair looks like: https://www.youtube.com/watch?v=APtiZ0WYQI4
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      I prefer desoldering/soldering usb-c port with a bga machine instead of hot gun. there are lots of tiny diodes near the port which often flow away 'coz of hot air gun. So be careful.
                                      Once you desolder the port,use lots of flux/iron and de soldering pump to clean all the pin holes.
                                      • D3D_Tray
                                        • Oct 2024
                                        • 11
                                        • BDR GmbH
                                        So late update but I DID IT!
                                        I managed to solder the new USB-C port and it work flawlessly now
                                        I used low-melt solder for the pads and on the anchor pins regular solder to give it more strength, hope that was not a bad thing to do for the long run :/
                                        Thank you all for your help and time, I never thought that I could make it but that was definitely a good start for me to get used to soldering with hot air and I hope, that I'll learn and do more with the time!
                                          DELL Latitude 5320 2in1 Hybrid (2-in-1) 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5320 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5320 2in1 boardview and 5320 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 03:40 AM
                                          DELL Latitude 5320 Notebook 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 5320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5320 boardview and 5320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5320...
