Dell Latitude 7390 charging but battery not increasing
  • dqtech
    Badcaps
    • Jul 2018
    • 632
    • N/A
    here the link for schematic - https://www.badcaps.net/forum/troubl...-the-bios-chip
    board number LA-F312P ....laptop charging but not increasing percentage...charge rate very low on BATMON ....i try use another battery also same result...but when i try this battery and adapter to another laptop (dell latitude 7300) its charging normally and charge rate goes to 19k-20k mW
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    ACOK/ACIN /HW_ACAVIN_NB status?
    Charging ic pin1-2 connectivity to PR917 intact as per rated resistance value?
    SDA/SCL communication on pin21/22 checked with DSO?
    PQ1202/1213-gate voltage?
    • dqtech
      Badcaps
      • Jul 2018
      • 632
      • N/A
      hi sir...here the update about this laptop...without battery
      ACOK = 3v
      ACIN = 3.5v
      HW_ACAVIN_NB = 3.3v
      PQ1202 gate = 18.5v
      PQ1213 gate = 1.2v
      Charging ic pin1-2 connectivity to PR917 = 1.5ohm
      ​SDA/SCL communication on pin21/22 checked with DSO? = is this need use Oscilloscope?..because i dont have it
      • mon2
        • Dec 2019
        • 14566
        Carry on with the debug guide as per mcplslg123.
        From your measurements,
        PQ1202 gate = 18.5v
        PQ1213 gate = 1.2v
        From the schematics, review the datasheet for these mosfets. From the datasheets, we know that each is a P-channel mosfet type.
        For a P-channel mosfet to turn on, the gate voltage must be lower than the voltage being passed between source / drain pins. PQ1213 should be ON based on the very low gate voltage.
        PQ1202, however, has the gate voltage at ~adapter voltage -> the voltage from the drain pins (5-6-7-8) is passing through the internal diode of PQ1202 and onto the source pins (1-2-3) and through the resistor @ PR1207.
        From this voltage we know that PQ1201B is OFF since the voltage at the gate pin is so high. That is, when PQ1201B is ON, the gate pin will be pulled to ground through PR1213 and together, PR1213 & PR1207 will build a voltage divider. This process will lower the gate voltage and fully turn on PQ1202.
        The voltage divider is not being enabled so this means VBUS1_ECOK is not a logic '1' to enable the mosfet @ PQ1201B (N-channel mosfet).
        Confirm the voltage to ground of VBUS1_ECOK.
        As a quick test, connect a piece of wire from PR1213 - pin # 2 - this pin is also mating with PQ1201B so double-check this trace. Other side of the wire to ground. We are bypassing the PQ1201B mosfet with this process. This will lower the gate voltage to enable the P-channel mosfet @ PQ1202.​
        • dqtech
          Badcaps
          • Jul 2018
          • 632
          • N/A
          VBUS1_ECOK = 0v
          PR1213 pin 2 jumper to ground ( i took from PQ1201 pin 1) = gate on PQ1202 become 1.7v sir and VBUS1_ECOK still remain 0v
          • mon2
            • Dec 2019
            • 14566
            When you did the PR1213 pin 2 jumper bypass, does the charge current change / increase at all?
            • dqtech
              Badcaps
              • Jul 2018
              • 632
              • N/A
              not increase sir....with and without battery current still around 0.600ma
              • mon2
                • Dec 2019
                • 14566
                Can you confirm the voltage to ground of the following?
                PJP102 ; +3.3V_ALWP
                PJP103 ; +5V_ALWP
                3.3V_ALW2 ; PU100 pin 17 LDO
                The EC is required to enable the VBUS1_ECOK ​signal but EC is powered by the above rails.
                Meter in resistance mode. Touch your meter probes together. What is the exact resistance in ohms?
                Next, place one meter prove directly on pin #1 of the charger IC @ PU901. Other meter probe directly on pin # 2. What is the exact resistance?
                It should be ~2 ohms. Total resistance = PR937 + PR938 + PR917 = 1 + 1 + 0.005 (too small to measure = 5 milliohms) = 2 ohms. This total resistance is important.
                • dqtech
                  Badcaps
                  • Jul 2018
                  • 632
                  • N/A
                  PJP102 ; +3.3V_ALWP
                  PJP103 ; +5V_ALWP
                  The EC is required to enable the VBUS1_ECOK signal but EC is powered by the above rails.
                  here sir..
                  PJP102 = 3.4v
                  PJP103 = 5.2v
                  PU100 pin 17 LDO = 3.3v
                  Meter in resistance mode. Touch your meter probes together. What is the exact resistance in ohms? = 0.000ohm
                  Next, place one meter prove directly on pin #1 of the charger IC @ PU901. Other meter probe directly on pin # 2. What is the exact resistance? = 2.7ohm​
                  • mon2
                    • Dec 2019
                    • 14566
                    Measure each of the resistors in this path individually.
                    Test PR937 (across the tips) and then PR938. Can you confirm that each is very close to 1R ohms each?
                    • dqtech
                      Badcaps
                      • Jul 2018
                      • 632
                      • N/A
                      here sir mon2
                      PR937 = 1.2 ohm
                      PR938 = 1.0 ohm
                      • mon2
                        • Dec 2019
                        • 14566
                        Ok. Now measure the last resistor which is the current sense resistor. This should be ~0Rohms since the schematics show as 5 milliohms.
                        • dqtech
                          Badcaps
                          • Jul 2018
                          • 632
                          • N/A
                          current sense resistor is PR901 right?... if so its 000.0 ohm sir
                          • mon2
                            • Dec 2019
                            • 14566
                            Repeat the resistance between pins 1&2 of the charger ic.
                            This should be 2R2 ohms not 2R7 as posted earlier.
                            If 2R7 ohms then one of the traces in this loop is defective. You will have to test each segment of the circuit to locate which trace is weak.
                              DELL Latitude 7390 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                              This specification for the DELL Latitude 7390 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                              09-06-2024, 11:05 AM
                              09-06-2024, 07:36 AM
