Lenovo IdeaPad S340-15IWL charging not working
  • radoslav baca
    • May 2024
    • 24
    • Slovakia
    Description : Lenovo
    Model : 81N8
    Serial Number :MP1LFDME
    Product Number : PRC4
    CN :
    MFD: 19/05/30
    MTM : 81N800BGCK
    Hard disk : NVMe 256GB P/N SSS0R27339
    CPU: Intel Core i3 8th generation
    RAM : DDR4 K4A8G16 4 x chip
    MB : EL5C3/EL531/EL431 LA-H101P Rev 1.0 2018/12/12
    I have a problem with my laptop. When I measure the connector where the adapter is connected between + and - it shows almost 0V. If I disconnect the connector from the motherboard, I measure between + and - 20 V. Can you advise me what the error is or what needs to be measured?​ I had the battery disconnected from the motherboard during the measurement.
  • mon2
    • Dec 2019
    • 14677
    Attached.
    Remove all power. Meter in resistance mode. Measure the resistance to ground on the main power rail (PL1 is ok; either side) that mates with the DCin power connector. Checking if the main power rail is shorted. What is the resistance in ohms?
    One meter lead to ground; other meter lead on PL1. Either meter lead color is ok.
    • radoslav baca
      • May 2024
      • 24
      • Slovakia
      Originally posted by mon2
      Attached.
      I measured PL1 and PF1 on both and it showed 305K ohms to ground.
      • mon2
        • Dec 2019
        • 14677
        Review PQ311 and PQ312. No power to the board. Meter in resistance mode.
        Measure the resistance across these mosfets:
        source / drain
        source / gate
        gate / drain
        Post each measurement. Each measurement should be hundreds of k ohms or higher. Otherwise the mosfet may be defective.
        • radoslav baca
          • May 2024
          • 24
          • Slovakia
          source / drain
          source / gate
          gate / drain
          PQ311
          S - D - 0,7 ohm
          S - G - 1ohm
          G - D - 1,3 ohm
          PQ312
          S - D - 294K ohm
          S - G - 1 ohm
          G - D - 304K ohm
          I found a datasheet for the PQ311 showing how the pins are arranged, but not for the PQ312, but I went according to what was shown on the pq311, that 4 pins are Drain, 3 pins are Source and 1 pin is Gate.
          • mon2
            • Dec 2019
            • 14677
            Both look nasty and shorted but start with fluxing and removing PQ311 off the board. Then (without power), measure the resistance again on PQ312. Need to confirm if the resistance values improve or not - especially the S/G @ 1 ohms.
            • radoslav baca
              • May 2024
              • 24
              • Slovakia
              I removed PQ311 from the motherboard and measured PQ312. G - S 1 ohm S - D 570K ohm and G - D - 575 K ohm
              • mon2
                • Dec 2019
                • 14677
                G-S is still low. Flux and remove this 2nd dcin mosfet. Also test the removed mosfet while it is on your workbench. Then measure the pcb pads in the same way. Still have a short? Also interested in the resistance to ground of each pin to confirm there is no other fault.
                • radoslav baca
                  • May 2024
                  • 24
                  • Slovakia
                  I also disconnected the second mosfet. When it was warm, it showed some values, but terribly high, over 700 K ohms. When it cooled down, I didn't measure anything anymore and the meter showed 0L between D-S and D-G. I also attach a photo when I measured the pins on the board. I measured the plus and minus from the other side of the connector to the other side of the board on the pin to see if there was a short circuit and everything beeped. Then I measured the internal pins and according to the picture you can see how they worked with each other.
                  • mon2
                    • Dec 2019
                    • 14677
                    Ok back from mind numbing grocery shopping. Each of the removed mosfets is with a high resistance for the above method of testing?
                    Test the PCB pads on the logic board. If the logic board is now with high resistance when testing only the PCB pads, then the mosfets are to blame. Clarify the details. Also interested in the resistance to ground of each pin on the PCB pads where these mosfets were soldered.
                    Need to be sure that the main power rail is not shorted.
                    • radoslav baca
                      • May 2024
                      • 24
                      • Slovakia
                      I measured through the resistor and the picture shows the result. Where I measured 365K ohm is the plus pole. I also measured the disconnected mosfet PQ311 and between all legs I measured 1 ohm, so this mosfet will be good. Mosfet PQ312 shows me infinity 0L.
                      • mon2
                        • Dec 2019
                        • 14677
                        See attached. Is this area shorted?
                        Test the removed mosfets. At least must be shorted to cause the readings reported earlier.
                        • coasterghost
                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                          by coasterghost
                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                          System Hardware:
                          Processor: AMD Ryzen 7 PRO 5850U
                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                          09-08-2025, 10:46 PM
                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                          09-07-2024, 05:20 AM
                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-07-2024, 05:00 AM
