Please Help , Asus Zenbook Motherboard repair
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    Please could someone help or advise me. I have an Asus Zenbook UX305UA that I am trying to repair. I'm still a newbie but I'm learning. Under a thermal cam I noticed that the TI 1285A IC is getting very hot. I checked the resistances to ground of all the pins connected to this chip, and found that pin 3 has a very low resistance of 1.8Ohms so I checked the Ceramic cap which is next in line, on continuity mode and the cap appears to be shorted. This is a 4.7uF 6.3V capacitor. My question is, do I need this cap? can I jump it? I have some donor boards laying around. What Cap would be an ok replacement if need be.
    Apologies if these are stupid questions. I'm still learning.
  • mon2
    • Dec 2019
    • 14247
    Yes, the capacitor is required to filter the rail and to assist during heavy current draw on the rail. Without this part, the voltage rail will dip under load.
    Where is this regulator on the board? Where is this cap on the board? The boardview will offer a part index. If not available, post a few pics of the area otherwise we will be searching for 'Waldo'.
    • roxboy1984
      • Jan 2022
      • 177
      • South Africa
      Thanks so much.. So the PWM chip is PU8701 and the cap is PC8702.
      • mon2
        • Dec 2019
        • 14247
        See attached.
        The critical parameters (in order) are:
        SMD size 0603
        voltage rating of 6v3 (or higher)
        capacitance of 4.7uF or higher
          • 20984
          Please post the boardview in this topic where everyone will be able to find it https://www.badcaps.net/forum/troubl...05ua-boardview ,then post a link to it from this topic. Thanks.
          • pc_okay
            • May 2022
            • 241
            • FRANCE
            Just to be clear, never jump caps and generally never jump any component or at least think twice before doing This. (For example if you jump a burnt fuse and there is still a short, you Will do hume damage!)
            Caps are often attached to ground on one side and current is not supposed to pass through. caps are open component so the current don't pass to ground through the caps (exept when they are failing, in that case the circuit is connected to ground and that's why you have a short to ground)
            On each Line all component are connected together, so if one caps is failing and is connected to ground all the Line become connected to ground and Of course all components are connected to ground.
            Sometimes you have Line With hundred component, you Will not replace all !?
            you have to determine which caps is dead:
            First by observation look for oxydation m, cracked burnt, component on the Line and on the board
            if you can't find anything you have to inject a Little current on the Line starting at very low voltage like 0,5V. And look for heat With thermal cam, cold gaz, colophane… because when short attract current and when a lot Of current pass through a component it heat.
            • roxboy1984
              • Jan 2022
              • 177
              • South Africa
              Please could someone confirm this for me. I have the following donor board that I'm looking for the necessary donor capacitor on. If I'm reading correctly the Cap "PC4723"on the Dell board would be a sufficient replacement for the Asus board?
              LINK to schematic https://www.badcaps.net/forum/troubl...=112466&nojs=1
              • roxboy1984
                • Jan 2022
                • 177
                • South Africa
                Ok so I'm now stuck. I don't think that the Cap is actually shorted as the resistance to ground with the cap removed on pin 3 of the PWM is still very low.
                The PWM IC is getting really hot. how would I test and see if the PWM IC itself is dead? Appreciate the help.
                • roxboy1984
                  • Jan 2022
                  • 177
                  • South Africa
                  is the TPS5128A and TPS5128B PWM IC interchangeable?
                  • mon2
                    • Dec 2019
                    • 14247
                    Since the rail is still low, you will have to pluck off the parts to hunt down the shorted part OR inject a low voltage if the resistance is low enough to cause the shorted part to heat up. What is the exact resistance to ground at this time (without the cap you have removed)?
                    Given that the PWM is heating up, suggest to carefully flux and remove this PWM IC. Then allow the board to cool and test the resistance to ground again of this low resistance rail. Did the resistance increase to a normal range? If yes, the PWM is defective and must be replaced. If not, keep hunting.
                    Take pics of the entire area before starting any rework.
                      • 20984
                      Read the datasheet https://www.ti.com/lit/gpn/TPS51285A
                      • roxboy1984
                        • Jan 2022
                        • 177
                        • South Africa
                        So the resistance to ground with the cap removed is still very low. Around 1.3ohms. So I don’t think the cap is the issue. I removed the PWM and checked the resistance on pin 3 and it was still low. Should I inject voltage on pin 3 with PWM removed and see what gets hot?
                        • mon2
                          • Dec 2019
                          • 14247
                          Yes, that would be the next stage. What I am suspecting is that the PCH who consumes the 3v3 rail may be the fault. Inject 1v or lower and test the thermals without a heatsink on the CPU.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            A short on +3V LDO will very likely lead to a shorted KBC and/or PCH. If you are lucky, it could be KBC only.
                            Warningont connect adapter while tps1285A is removed.
                              ASUS ZenBook UX305UA-FC006R Notebook Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook UX305UA-FC006R Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX305UA-FC006R boardview and UX305UA-FC006R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 08:27 AM
                              ASUS ZenBook UX305UA-FB055T Notebook Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook UX305UA-FB055T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX305UA-FB055T boardview and UX305UA-FB055T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:54 AM
                              ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              09-07-2024, 06:31 AM
                              ASUS ZenBook S UX370UA Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook S UX370UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S UX370UA boardview and S UX370UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 06:24 AM
                              ASUS ZenBook UX550VD-BN011T Notebook Pro Specification for Upgrade or Repair
                              This specification for the ASUS ZenBook UX550VD-BN011T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BN011T boardview and UX550VD-BN011T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 06:08 AM
