macbook a1989 820-00850 no camera
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    Hello friends. There is a problem, the camera does not work. Replacing the display did not bring results. The problem is on the board. Please tell me where to look?
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    • mon2
      • Dec 2019
      • 14120
      https://boards.rossmanngroup.com/thr...-camera.64340/
      • PITERPENY
        • Jul 2023
        • 455
        • Ukraine
        Thank you for the link. Unfortunately, the person never answered whether he managed to fix it. Restoring via DFU did not help me. Neither did replacing U8502. Any other thoughts on what could be wrong?
        • mon2
          • Dec 2019
          • 14120
          What is the voltage to ground of SEP_CAM_DISABLE_DFF_L on U8502? This is the select pin for the camera.
          If L = Camera Disable
          If H = Camera Enable
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            SEP_CAM_DISABLE_DFF_L​=1.8V(diod=0.577)
            ​​​​​​I have seen several threads with this problem on boards.rossmanngroup.com and as I understand their repairs were not successful!
            • mon2
              • Dec 2019
              • 14120
              The display is 100% compatible with this chassis?
              Is the camera being detected by the logic board and just not working?
              What are the voltage to ground measurements for:
              I2C_FTCAM_ISOL_SDA
              I2C_FTCAM_ISOL_SCL
              The enable voltage is correct to enable the MUX. After the mux is enabled, the rest is about the MIPI lines to send the data out of the camera to the host board (MIPI CSI interface).
              Be sure the EMI filters are present and soldered. You can test each in DIODE mode (without power) - measure across the part. Each should be ~0v in diode mode = short. Otherwise, the EMI filters are defective or not soldered properly.
              • PITERPENY
                • Jul 2023
                • 455
                • Ukraine
                I2C_FTCAM_ISOL_SDA=0.576
                I2C_FTCAM_ISOL_SCL=0.567
                EMI filters OK=0v
                • mon2
                  • Dec 2019
                  • 14120
                  Is the camera being detected by the logic board and just not working?​
                  • PITERPENY
                    • Jul 2023
                    • 455
                    • Ukraine
                    no camera is not detected. I put the board in a known working case with a 100% working camera, but the board simply does not see the camera. At the same time, the light sensor, which is on the camera module, works properly. I will note that there is not even an attempt to connect to the camera. That is, there is no green light blinking. It is as if the camera simply does not exist. I think that you need to try replacing the T2
