Lenovo Flex not charging
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi people!
    The board is LC57-IAU MB 213062 -1M.
    Here is High res board picture, i could not find a schematic
    what i have:
    the board is working on battery, without battery type c remains on 5v with battery it is changing to 20v (0A pulled by board), but it powers on.
    charging IC was replaced with same results.
    attached pictures of what i have so far and also the PD controller
    can you please help me understand why no charging ?
  • mon2
    • Dec 2019
    • 14659
    Hi. Same PU4401 appears on other Flex 5 schematics so they can be used for reference to debug.
    • koby058
      • Jan 2017
      • 387
      • israel
      Thanks mon2 for you reply, in this schematic it looks like a bq25710 chip not southchip
      Also, how would you suggest me to continue the debug?
      Is thee a post/video that explains how main power rail is created in this kind of circuit ?
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        The charging circuit whose measurements I recorded before. It may help.
        I'm not happy to be so strong. because it's not humanly
        • koby058
          • Jan 2017
          • 387
          • israel
          I can see that on pin4 CHRG_OK is missing, also on the left dual mosfet i see 12.5v or 5v when no battery, what is changing the voltage to 12.5v from 20v?
          Can any one advise?
          • mon2
            • Dec 2019
            • 14659
            Attached. If PWR_CHG_ACOK = 0v then review this circuit and also if the mosfet is open or closed @ PQ4404. It appears to be enabled so this is pulling the PWR_CHG_ACOK line to 0v.
            Short answer is that, the gate voltage should be 0v or ground from the EC. Only if the gate is OFF = 0v, then you will have a voltage @ PWR_CHG_ACOK.
            Click image for larger version  Name:	acok.png Views:	0 Size:	62.3 KB ID:	3608575
            • koby058
              • Jan 2017
              • 387
              • israel
              The gate is shorted to ground,
              I am not sure i understand you on this line:
              Short answer is that, the gate voltage should be 0v or ground from the EC. Only if the gate is OFF = 0v, then you will have a voltage @ PWR_CHG_ACOK.​
              • mon2
                • Dec 2019
                • 14659
                This mosfet is disabled. If the mosfet is off, there must be a voltage at the circled point. Confirm the voltage on each side of resistor @ PR4432.
                • koby058
                  • Jan 2017
                  • 387
                  • israel
                  I cannot find it, i measure the one on the attached pic (red dot)
                  left side 0.4v right side 0v
                  I can also see that on the charger IC pin7 vdda looks shorted with only 1.6ohms
                  • mon2
                    • Dec 2019
                    • 14659
                    We have different boards for this Flex 5. Let check others.
                    • mon2
                      • Dec 2019
                      • 14659
                      PQ4404 on my shared partial schematic is most likely not the same PQ4404 on yours unless we can confirm the wiring back to the charger IC. For my shared schematic, the PWR_CHG_ACOK pin is linked to this mosfet.
                      • mon2
                        • Dec 2019
                        • 14659
                        Attached is what may be a similar datasheet for the part on your board.
                        Manufacturer: Southchip (my first time hearing of this company out of China).
                        • koby058
                          • Jan 2017
                          • 387
                          • israel
                          so i found that the charger ic was shorted, i have replaced it again and now i have charging light but still not charging
                          on pin 22 i can see that i have batt voltage
                          ican see that batdev is 0
                          can yoo advise on how i can continue here ?
                          • koby058
                            • Jan 2017
                            • 387
                            • israel
                            CHRG_OK is 2.8v and i understand it must be 3.3, is this correct ?
                            pin detail from chip schematic
                            Open drain active high output. CHRG_OK outputs logic high indicating VBUS is in the range of 3.5V
                            to 24V and no fault occurs​
                            • jadao
                              • Sep 2015
                              • 10
                              Hello, just to let you know the chip SOUTHCHIP SC8885L found in a NM-E211 rev 1.0 board (Lenovo Thinkpad E14 Gen 4) was perfectly replaced by a BQ25710, The boardview and schematics show a BQ25710 but the reality on the board is a southchip SC8885L. All surrounding component and their values were exactly as per the schematic.
                              So i gave a try and it worked perfect, it seems to be an equivalent.
                              Datasheet for BQ25710 is available, for southchip SC8885L I only found SC8885C.
                              The original southchip on the board suffered from liquid damage, its internal LDO on the REGN pin 28 was 5.1V instead of 6V.
                              I hope this may help someone.
                              • mon2
                                • Dec 2019
                                • 14659
                                jadao, awesome find!! Thanks for sharing.
                                • koby058
                                  • Jan 2017
                                  • 387
                                  • israel
                                  Thanks for your reply
                                  i have replaced the two switching mosfets and now i get charging light but the board pulling 0.3-0.5A fluctuating
                                  but now i hear clicking sound from the mosfets /chatger IC area, i have tried another SC8885L​ and i am getting the noises as well
                                  I only have BQ25700A in stock and i cannot believe the customer will wait for an order
                                  do you think it can come instead of BQ25710 ?
                                  Any other suggestion ?
                                  • mon2
                                    • Dec 2019
                                    • 14659
                                    I would be concerned with the mv step resolution as shown in the following comparison chart:
                                    https://e2e.ti.com/support/power-man...with-a-bq25700
                                    • coasterghost
                                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                      by coasterghost
                                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                      System Hardware:
                                      Processor: AMD Ryzen 7 PRO 5850U
                                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                      09-08-2025, 10:46 PM
                                    • Khoja
                                      Lenovo Ideapad Flex 5 14IAU7 (LC57-IAU MB 213062-1M) identifying elements
                                      by Khoja
                                      Hello friends, I have a Lenovo Ideapad Flex 5 14IAU7 laptop that doesn’t turn on. When I opened it, I found a burnt resistor on the motherboard. Since I couldn’t find a schematic for this model, I need help identifying the parameters of this resistor.
                                      • Model: Lenovo Ideapad Flex 5 14IAU7
                                      • SN: PW0AZK3W
                                      • Motherboard: LC57-IAU MB 213062-1M 448.0RH09.001M
                                      Any assistance would be greatly appreciated!...
                                      09-19-2025, 09:56 AM
                                      Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                      09-07-2024, 07:20 AM
                                      09-07-2024, 06:38 AM
