Omen laptop DA0G3EMBCD0, shor circuit from USB
  • ryogadan78
    • Nov 2021
    • 66
    • Italia
    Good morning guys. I have my Omen laptop (DA0G3EMBCD0) that now gives no signs of life (no LED).
    During the night I misplugged a slim usbdrive which had the shield damaged, I guess I caused a short because the laptop turned off and never turned on again.
    After taking it apart I noticed with the thermal imaging camera that two ICs on the mainboard reach 100 degrees Celsius. Thanks to the boardview I saw that they are PU8600 and PU8601. I tested the pins of these ICs and found these anomalies compared to the schematic
    PU8600
    6 (3VS5_LX) - 5 OHM to ground (normal?)
    14 (3VS5VOUT) - SHORT TO GND
    17 (+3VPCU) - SHORT TO GND
    19 (3VS5_LX) - 5 OHM to ground (normal?)
    PU8601
    6 (5VS5_LX) - GND
    19 GND - SHORT TO GND
    20 GND - SHORT TO GND
    Suggestions on how to proceed?​
  • mon2
    • Dec 2019
    • 13894
    Have not reviewed the schematics yet but locate the local usb load switch for the shorted usb port.
    Is that part defective on the vbus rail? Post the resistance to ground measurement. No power during this measurement.
    • ryogadan78
      • Nov 2021
      • 66
      • Italia
      Hi Mon2, you are always so kind to reply.
      I only have the boardview of this board and probably wouldn't have the experience to read a schematic. Could you help me? identify the components to be tested by the name they have in the boardview?​
      • mon2
        • Dec 2019
        • 13894
        Certainly. Apparently, I also have only the boardview in my database service.
        The process is to locate the USB port name that faced this shorting event. Then find this port on the boardview diagram. Select the pin that is linked to the VBUS power rail.
        Using internet (google), the USB connector pinout should be public since this is an industry wide specification. That is, if the connector is USB 2.0 -> search for USB 2.0 pinout. If USB 3.0 connector -> search for USB 3.0 pinout. The insulator in the connector is used to identify the speed from the outside of the logic board.
        Black insulator = USB 2.0
        Purple / Blue insulator = USB 3.x.
        Your focus is to identify the port name and then VBUS on that port. Once you highlight this pin, the next component in line will be lit up in the boardview drawing.
        Often, there are local USB load switches which act like current limited electronic fuses. They 'should' prevent damage to the board but often fail and do not react in time.
        • ryogadan78
          • Nov 2021
          • 66
          • Italia
          OK the procedure should not be complicated also because I caused the short on the only USBC port. I have to leave the lab now but I will do the research as soon as possible and update you
          • ryogadan78
            • Nov 2021
            • 66
            • Italia
            In the boardview, the USBC connector is marked as CNP1. The TBTA_VBUS_L pin is connected to pin 10 of an IC marked on the boardview as UP1. I enclose a photo pointing out that two nearby capacitors are shorted to ground on both pins
            • ryogadan78
              • Nov 2021
              • 66
              • Italia
              Hi Mon2, I don't know if you saw my answer. Unfortunately I don't really know how to proceed considering that the VBUS comes to this IC. Any suggestions?
              • mon2
                • Dec 2019
                • 13894
                Flux and remove each of these capacitors. Keep notes of their locations. Then measure the resistance again without these parts. No power to the board.
                • mon2
                  • Dec 2019
                  • 13894
                  Not sure if our posts are in sync but note that there is a VBUS input from the external power source / adapter then there is the secondary side of this power rail that follows after some internal mosfets inside of this power delivery (PD) controller. If you are truly noting a shorted region on the board like the 2 highlighted caps then flux and remove each. Then test the resistance to ground on the same pcb pads to confirm if the shorts are removed or not.
                  • ryogadan78
                    • Nov 2021
                    • 66
                    • Italia
                    Done, the short circuit still seems to be present. Resistance to ground is 0.4ohm
                    • ryogadan78
                      • Nov 2021
                      • 66
                      • Italia
                      I injected 1V on the 5V pin of one of the capacitors on which I detected a short to ground. With the thermal camera, I identified an area of the mainboard that I had not inspected and found this nice surprise. Based on the boardview IC it is PU8700. Any suggestions?
                      • ryogadan78
                        • Nov 2021
                        • 66
                        • Italia
                        Hi Mon2, I don't know if you have seen the latest updates, I need your help. I really wouldn't know how to go on
                        • mon2
                          • Dec 2019
                          • 13894
                          What are the topside markings on PU8700?
                          The region of this area looks to be burnt or is this bad flux?
                          Also, share a larger pic of this area. We are reviewing the same boardview and to me, this is not PU8700. The surrounding parts do not match your board pic.
                          • ryogadan78
                            • Nov 2021
                            • 66
                            • Italia
                            Hi Mon2, sorry I have not been present. Health problems. Here I am with you. I am enclosing a photo where you can see the initials above the chip and a photo showing a larger area of the mainboard. I actually noticed too that the boardview file does not match 100%.
                            The region of this area is burnt
                            Topside marking of IC
                            51486
                            TI OA8
                            AEP5
                            • ryogadan78
                              • Nov 2021
                              • 66
                              • Italia
                              Hi Mon2, do I start disconnecting ICs and cleaning the mainboard?
                              • ryogadan78
                                • Nov 2021
                                • 66
                                • Italia
                                ​I don't want to bother you, just to know if you think I can go ahead with the repair or is it too complicated
                                • mon2
                                  • Dec 2019
                                  • 13894
                                  Review the bottom side of the 51486 chip - appears that one pin (at least) is missing. There should be 5 contacts on the bottom side that appears to be 'burnt' looking.
                                  • ryogadan78
                                    • Nov 2021
                                    • 66
                                    • Italia
                                    Here are two photos, of the chip and what I see under the mainboard. Could I clean the mainboard a bit to find out if there is any more damage?
                                    • ryogadan78
                                      • Nov 2021
                                      • 66
                                      • Italia
                                      It seems that my boardview is not exactly identical to my mainboard
                                      • mon2
                                        • Dec 2019
                                        • 13894
                                        I see the same BV in my (paid) database of schematics. The surrounding parts are not 100% matching your board under repair. This regulator (PU8700) appears to be linked to the RAM sockets to the left of this part.
                                        Are there any other markings on the logic board that may help to locate a schematic / more accurate BV?
                                          HP OMEN X OMEN X by 900-187na OMEN X i7-7700K Specification for Upgrade or Repair
                                          This specification for the HP OMEN X OMEN X by 900-187na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by 900-187na boardview and OMEN X OMEN X by 900-187na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:44 PM
                                          HP OMEN OMEN 870-033ng OMEN 870 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN 870-033ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN 870-033ng boardview and OMEN OMEN 870-033ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) OMEN i7-6700 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-060na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
