Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
  • Simone Vergani
    • Feb 2025
    • 10
    • Italy
    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
    To assist with troubleshooting, I'm attaching two power circuit schematics:
    • Power Circuit 1 (Initial schematic showing the battery and DC jack connections)
    • Power Circuit 2 (Detailed power circuit diagram)
    I'm relatively new to reading these schematics, and I would greatly appreciate it if someone could help me understand the COMPAL nomenclature used in the diagrams, such as: BATT++, VIN, B+, P1, P2, CHG_B+, etc.
    Additionally, I've disassembled the laptop and noticed an odd component that seems to be damaged. On the schematic, it's labeled as PL701, and it appears to be burnt. I've attached a photo of it as well.
    If anyone can offer insight into whether the issue is related to a MOSFET, capacitor, inductor, or if the damaged component might be causing the charging problem, I would be immensely grateful for your help in resolving this issue.
    Thank you so much in advance for any assistance!
    Best regards,
    Simone
  • mon2
    • Dec 2019
    • 14636
    What is the LA-**** number on the silk screening of your board? This will identify the possible schematic we need to review.
    • Simone Vergani
      • Feb 2025
      • 10
      • Italy
      Then the full name of the motherboard is: AAP20 LA-B753P Rev: 1.0 (A00)
      Thank you so much!
      • Simone Vergani
        • Feb 2025
        • 10
        • Italy
        For information, I attached the power supply circuits in the previous message (pdf file) but in any case in the schematics file they are found on pages 58 and 59. (I attach the complete diagram in pdf)
        Link to schematic - https://www.badcaps.net/forum/troubl...753p-schematic
        • Simone Vergani
          • Feb 2025
          • 10
          • Italy
          Any News?
          • mon2
            • Dec 2019
            • 14636
            This is a Dell so the adapter must present a working PS_ID signal line. This 1-wire interface is used to announce the capabilities of the power adapter. In the absence of this signal, the adapter will be treated as a weak unit that is not capable of charging and the CPU speed will also be throttled.
            What does the BIOS report on the power rating of this adapter? You must be using a 240W rated power adapter and it must be from Dell / Alienware else the PSID line will be missing.
            Measure the voltage to ground on PL2 (either side) with the power adapter connected. Post the measurement.
            • piernov
              Laptop battery charging circuit
              by piernov
              1. Some theory
              1.1. Introduction
              Almost every laptop has a charging circuit of some sort, that does a few things:
              • Manages switching between AC adapter and battery power
              • Manages battery charging and generates power rail to charge battery
              There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
              • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
              • Narrow VDC (NVDC)
              Texas instrument has a nice overview of these technologies with some more details at https:...
              11-15-2020, 01:31 PM
            • drlarsen
              MacBook Air M1 A2337 battery/charging issue
              by drlarsen
              Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
              I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
              On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
              After some hours, the battery status did not improve. Restore via DFU did not help.
              I connected the power adapter to a Kill-a-Watt...
              07-17-2025, 02:35 PM
            • code share
              Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
              by code share
              I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
              Here's what I've tried so far:
              • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
              • Booted successfully on AC power only with the battery disconnected
              • Visual inspection of the battery — no swelling, burn marks, or connector damage
              • Battery
              04-21-2025, 12:50 PM
            • Iherduleikgemz
              Asus FX505DY - Battery not charging - BQ24780S
              by Iherduleikgemz
              Hello everyone
              I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
              I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
              01-13-2025, 03:54 PM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
