Manged to get a hold of an iPad Pro 11" 4th Gen however it does not charge and upon opening it looks like someone has tried to replace the port and knocked a component off but I cannot find a schematic or boardview for this model so was wondering if anyone could help identify what I think is a missing pad and capacitor? Looks like whoever was in here last tried to put it back on with hot air and melted the plastics too...
iPad Pro 11-inch (4th Generation) A2759 - Missing component
Thank you so much for sharing this. The yellow pad is missing as well so I'm going to assume where that trace to the left isn't connected to somewhere that the line draws to the right towards what is most probably U22A1 (also very likely under the shield unless i can connect a wire somewhere else). I've got the iPad switched on and it seems to be mostly working aside from the lack of charging which is expected if a trace is missingComment
I hope someone can help me too.
It is also an ipad pro 11 4th generation A2759
I received an iPad from a repair shop, and while replacing the charging port, they tore off the components shown in the picture. :-(
What are these missing components?
Can anyone help me with the circuit diagram and the names of the components?
Thank you very muchComment
Thank you for your reply. Unfortunately, I don't have any documents from other iPads. It would be great if you could take a look at the documents.
Thank you.Comment
by GeirAndersenI tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
IPAD COLLECTION 1
+---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
+---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
+---iPad mini3 820-00008(A1599) 820-00002(A1600)
+---iPad mini4 820-00180(A1538) 820-00177(A1550)
+---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
+---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...-
Channel: Schematic Requests ONLY!
by grimacelordHello.
Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
For example, when I connect the iPad to... -
Apple iPad 4th Generation 820-3249 Boardview and Schematic...
Channel: Schematics and Boardviews
11-01-2024, 02:45 PM -
by vbogoevHello,
I bought an iPad 4 from eBay which is not powering on and wanted to troubleshoot the problem just for fun.
But the fun ended when I stuck... I don't know what to do next and I'll be thankful for a bit of help.
What I know so far:
Pluging the iPad to the charger charging the battery with around 2.3-2.4A, which is OK IMO.
Pressing the power button does nothing. Press and hold the power button + home button (to reset the device) does nothing (it is resetting but still doesn't turn on).
I dissassembled the tablet...11-19-2021, 04:46 PM -
by ntchickenHi everyone,
My iPad suddenly stopped working and does not turn on and is not detected by a computer. When I plugged it in and measured, it read the following:
5V, 0.5A, 2.5W (both with and without a battery).
I opened it up to look for obvious signs of damage but I can't seem to see anything with my untrained eyes. I took my multimeter, set it to continuity and tested the resistors and diodes for any shorts.
Below, everything circled or boxed in yellow is shorted. Would anyone have any idea what the issue is based on the pictures and how to... - Loading...
